10-19-2010, 08:15 PM   #46
QuoteOriginally posted by JonPB Quote
For someone who is interested in testing this, take a pre-A lens, or an A, F or FA lens set to apertures other than A, and use Av mode in a controlled and constant lighting environment; for each stop of adjustment on the aperture ring, the shutter speed should double or halve.
No, AV mode always shoots wide open no matter where you set the aperture ring. You need to use M mode and check whether changing a stop on the aperture ring, and then pressing the green button, leads to a recommendation that is one stop different. AV mode can only be used if a lens is in A mode, and I never had exposure difficulties in A mode.
10-19-2010, 08:47 PM   #47
jeff knight's Avatar
Ok, so catch in focus is faster. What I am really desperate to know is how accurate is trap focusing with the K5 in low light using manual glass. I am positively desperate to know this! I use a K20d. It's very hit and miss.
Someone? Anyone?
10-19-2010, 09:55 PM   #48
ovim's Avatar
QuoteOriginally posted by paperbag846 Quote
Actually Av can be used with M42 lenses and then JonPBs test can be carried out but only with M42:
With K-R I doubt nothing has changed since erlier bodies and if you use AV with M42 lenses you get exposure errors if the contacts on the mount are not shorted correctly. I have to dial in +1.5-2EV with my K200D with certain M42 lenses to get exposure right.
It'd be nice if someone could tell me it isn't so
10-20-2010, 02:00 AM   #49
Using manual lenses (M42, Nikkor, M, etc) can you set AF points for catch-in focus?
It would be awesome if you can.
camera, dslr, k-5, k-5 ii, k-5 iis, k-r, k5, lenses, pentax k-5
Manual Metering on Pentax DSLRs with Manual and Automatic Lenses Adam Pentax DSLR and Camera Articles 20 01-06-2016 03:38 AM
Pentax Km and old manual lenses: SMC Takumars & Tamron Adaptall 2 lenses Kendrick Troubleshooting and Beginner Help 10 04-14-2010 03:23 AM
K7 and Manual Lenses IainG Pentax DSLR Discussion 9 02-13-2010 04:49 AM
Help with manual lenses on K-x stonedes Pentax DSLR Discussion 3 02-08-2010 10:31 AM
Manual lenses? Seltzer Pentax SLR Lens Discussion 1 05-29-2008 08:17 AM
All times are GMT -7. The time now is 06:13 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
