10-25-2010, 11:15 AM   #1
My K5 has problem or....really a big bug!
Once I try to shoot some high iso photo (iso 12800, 25600 or 51200), I find that when I set the NR other than AUTO mode. The photo comes out with strange color...... This happens frequently for ISO 51200......
Any one have the same problem???
PENTAX K-5  Photo
10-25-2010, 11:20 AM   #2
It looks like you have cross-processing turned on
10-25-2010, 11:25 AM   #3
I have turned it off.
When I got a problem photo, I changed iso to 800 and shoot again, the photo was normal....
Once I change it back to 51200......It happened again......
10-25-2010, 11:28 AM   #4
JohnBee's Avatar
I'd try resetting everything, removing battery etc. it before calling it.
If it does it after that... I think it's quite clear what needs to be done.
10-25-2010, 11:42 AM   #5
It's pretty hard to tell what color the picture really looks like at 51200 on my K-5 because of all the noise, but I didn't notice anything particularly off at 12800 or 25600, Auto NR Off, JPEG or RAW. The chroma noise at 51200 can make the color look somewhat off, but overall the color looks roughly correct on my camera.
You're going to have to post larger pictures from both low and high ISO for us to be able to see what's going on. We can't tell anything from that small photo, because we don't know what that scene looks like at low ISO.
EDIT: Unless you're talking about the yellow band in the middle of that picture. Is it supposed to be more or less white across the whole thing? If so, then no, my camera doesn't do that.
Not that I personally would ever really use 51200, or 25600 for that matter anyway. There's a reason they're "expanded" ISO, and not selectable by default. Unless you have crazy NR skills like JohnBee, they're not really usable.
10-25-2010, 11:59 AM   #6
Wheatfield's Avatar
I don't suppose that picture is illuminated by florescent light is it?
10-25-2010, 12:07 PM   #7
What sort of lighting? I got something similar at a Hockey game once under some sort of Sodium lighting. It gave a strobe effect and a strange color tone.
10-25-2010, 12:08 PM   #8
Thats the right question to start. I use 5000K compact flourescent lamps to examine prints at night. I get some shots looking exactly like the OPs sample when I use the lamps to light a focus chart.
10-25-2010, 12:56 PM   #9
Yeah, fluorescents will cause weird color banding.
10-25-2010, 01:17 PM   #10
Clicker's Avatar
Looks like a flouresent tube reflection ... indoors i always manually set my WB.
10-25-2010, 01:30 PM   #11
The reason that you are getting banding at some ISO's and not others if you are shooting under florescent or other light with a definite flicker is that the shutter speed will vary with the ISO and the flicker will produce these off color banding effects that will coincide with those shutter speeds. Try the camera outdoors in daylight at the higher ISO's and I believe these issues will be absent.
10-25-2010, 01:52 PM - 1 Like   #12
inferno10's Avatar
Definitely appears to be fluorescent lighting. Based on the EXIF, you were shooting at 1/1250s. Fluroescent lighting usually flickers on and off at twice the frequency of your current (usually either 1/120s or 1/100s, depending where you live). Because your shutter speed was faster than the cycle time for the light, your camera captured the time between an on and off phase. If you sync up your shutter speed to 1/60s or 1/50s (again depending on your mains frequency), you shouldn't see that band appear anymore, as the fluorescent light will have fully cycled on/off, thus evenly filling the scene with light.
The other issue w/ fluorescent lighting is that the spectrum of light isn't nearly as wide as other light, so you'll still need to fix the white balance with the image.
In short, this is not a problem with your K-5; any camera can experience this issue, as it's mainly due to shutter-speed .
- Jason
10-25-2010, 07:24 PM   #13
I don't think I've ever been in a bright enough place under artificial lighting to use 1/1250 sec shutter speed.
I guess this is unchartered territory, made possible by the K-5's unbelievable ISO range.
If you can't replicate the problem under normal sunlight, then that's the likely explanation, and the solution is to avoid such a high shutter speed indoors.
10-25-2010, 07:35 PM   #14
twitch's Avatar
I've heard of this problem with floruesent lights and high shutter speeds. Short answer is there is nothing wrong with the camera, it's simply a "feature" of that type of lighting that isn't visible to the naked eye, but is only seen when captured on a camera at a fast enough shutter speed.
10-25-2010, 07:51 PM   #15
Another "effect" you may see under fluorescent lights, especially the long-tube types, if your shutter speed is fast enough - you may see different parts of the room unevenly lit.
The human eye doesn't react fast enough to "see" this...
camera, dslr, iso, k-5, k-5 ii, k-5 iis, k5, pentax k-5, photo
K-7 Big Problem? robr7 Troubleshooting and Beginner Help 12 10-04-2010 08:13 AM
Macro Big grasshopper and a beetle bug r0ckstarr Post Your Photos! 3 08-29-2010 07:54 AM
Possible camera problem - or lightroom bug? jerrymouse Pentax DSLR Discussion 7 04-09-2009 12:18 AM
Big Problem with my Video Card..I think...Big Ca Ca benjikan General Talk 19 03-18-2007 11:45 PM
Big bug Arpe Post Your Photos! 4 10-16-2006 02:39 AM
All times are GMT -7. The time now is 05:54 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
