This is impressive. I wanted to see if I could do something similar with my k7 so I found a photo I'd taken on Manual while set up for the Key West Sunset. I turned the camera and took a couple pictures before realizing I was on M. I think the WB was on Daylight, not sure, but I know the other settings were:
Shutter Speed: 1/160
Aperture: f8
ISO: 100
Lens: DA 16-50 @ 50mm (75 equiv)
I always shoot in RAW+ so the second is an untouched jpeg, and the first is after pushing its' RAW counterpart four stops in ACR, and another in post.
I think that's all I did. I was going to try to reduce the noise, but don't have a good program for that yet, and don't know how to use CS5 well enough yet. I'm sure some of you could do much better than I did recovering an arguably unusable photo, but after seeing above I just wanted to give it a try. The nicest thing about Pentax is that after a couple shots I hit the green button and got much better results.
I know this isn't in the same league as the k5, but I really like the k7.
Bill
