Originally posted by dave kitson I think that the damage that creampuff refers to is to the GGS screen, not the LCD screen.
The GGS protector is rigid, and any flexing during removal operations is likely to fracture it. The adhesive tape should only make contact with the LCD surround, not the LCD screen itself.
EDIT: Added image
dave
Dave,
Thanks for your user comments, while according to the information provided by local seller, there IS a risk that the GGS protector breaks off and the fragments possibly damage the screen if you force it off using your finger nail, this possible incident is simply thanks to its rigitity and the stickiness of the 3M adhesive. Comparing to it, mormal PET protectors-might not be as rigid, but much more flexible and replacable.
The suggested instruction of removing a GGS protector is using a hard thin PVC slice, insert it into any point at the edge of the protector, then move the slice gently along the edge of the screen, since there is actually no adhesive at the center of the protector, it will be thus removed.
