Originally posted by blende8 What I still don't know is what it is doing.
AFAIK, it's a motor.
Normally, if you mount a lens, the aperture lever is turned by the force of mounting the lens. So, the lens is aperture open as soon as it is mounted and closed when off.
If you make a shot, the lever is released and the aperture spring closes the lens until the predetermined stop. After the shot, the lever is brought back into mounted position by the same mechanics which rewinds the shutter curtains and lowers the mirror.
This spring/block/rewind mechanics can only move the block position (change the f-stop) if the lever is disengaged, i.e., if the block has no pressure from the lever and aperture spring. I.e., the aperture must be fully open to change the f-stop (in A position).
With the K-7/5, the body-side lever isn't a spring/block mechanics anymore. It's a motor which is powerful enough to push the lever against the aperture spring force and precise enough to push it exactly into the desired position. A side effect is that a manual aperture ring (non A position) seems to have no effect anymore.
This change became necessary to allow a change of f-stop during LV and especially, during video recording.
Actually, I'm not sure how many brands allow a fully automatic aperture control during video with legacy lenses.
The noise at the beginning doesn't close down the lens. So, it's not from moving the aperture lever by any significant distance. The noise from moving the aperture lever for stopping down is similiar but not as loud. But if you look very careful upon start-up with no lens, you'll see that the scratch noise is from the lever vibrating by ~1/4 mm for as long as the noise lasts. So, it may try to probe for some start position or to calibrate some motor parameter.
---------- Post added 11-21-10 at 06:28 PM ----------
Originally posted by inferno10 For me, it was the opposite. You could hear my K-7's DR mechanism, which sounded like a hand screeching across a clean pane of glass or a nail going across a chalkboard; this was still barely audible, but was discernible from the first sound. In the case with my rental K-5, the DR mechanism was even less audible.
Jason, what I said. Double negation and English language
