Originally posted by ogl Falk, I've converted PEF from K20D and K-5 yesterday and it seems to me that K20D has just a bit thicker AA filter than K10D and K200D or K-x. The photos are really sharp.
K-5 has stronger AA filter than K20D. Can you test it more carefully?
ogl, you confused the threads. This isn't your favourite AA filter thread
But let me give you this
one reply in this thread since you asked.
From what I've seen and heard, the K10D has an AA filter which only blurs vertical lines (anisotrop AA filter). K20D seems to blur both directions (isotrop AA filter). The K-7 seems to have a slightly weaker isotrop AA filter than K20D. K-5 seems to have the same physical AA filter as K-7 which may make a measurebators difference because the pixel pitch is 5% smaller. All four AA filters do
not blur away Nyquist frequency patterns, ie., they belong into the class of so-called weak AA filters. I cannot compare K20D and K-5 directly.
But I can say that without some sophistication, all four cameras with a good lens, are sharp enough to measure focus accuracy rather than camera resolution. So, results will be random. I get best results around f/4 because diffraction already hurts at f/5.6 and focus at f/4 is .... an untamed beast
If everything is setup in an optimal way, at f/4.5 the K-5 MTF22 "resolution" equals Nyquist with a LR-sharpening of 50% and 0.5px only, which happens to be the mathematical value from an ideal lens from a Foveon sensor w/o AA filter. So, LR-sharpening of 50% and 0.5px (LR 2.x) seems to invert the AA-filter pretty well. The real reason for a weaker AA filter is that natural blur can replace part of it...
Actually, the shutter-induced blur between 1/160s and 1/40s would be able to replace a good part of the K-5's AA filter in the horizontal direction. But only for free hand photography and not for faster, slower or flash photography
Nevertheless, I wonder if Pentax didn't suspect shutter blur for the K10D to be larger than it actually was
