Originally posted by Kenn100D Does anybody here have an electron microscope? i think we can see the problem more clearly.
While it's a great idea, it's not actually needed.
The particles are pretty large. With reversed lens macroscopy, we should be able to get a very good photograph of the particles.
If the particles have a smile on their face, we would clearly see it
The trick is to mount a, say '50 to the K-5 and a '300 to another camera like a K-7. Then use a reverse filter ring and step rings to connect the two filter rings and cameras.
And then photograph the K-5 inerds (in bulb mode) using the K-7. The '50's focus wheel is used to shift the subject plane to the required location where everything above the sensor surface is easily adjusted.
Because the entire is sealed from light, you have to place a small LED with battery (gift shop article) in the bottom of the K-5 mirror box before mounting the '50.
In the end, you get a 1µm resolution image of the particle making it about 40x40 pixels large. So, a Raynox image is 1/50 of what's feasible with equipment on board.
