I never used the USER mode on my K7... Not much freedom, and I never really found a real use to this...
But now faced with 5 USER modes, I started to play around with settings, and things started to fall in place quite nicely...
I've made some quick tests to see what exactly is stored in these USER modes, and apart from the AF fine tuning value, it seems like everything can be recorded...
What is really neat is the ability to record the program line and the auto-iso handling (which are quite hard to change, as they are quite buried into the menus, even with the quick settings access we now have!).
Which gave me some neat (I suppose!) ideas I want to share with you, so if it can help others...
I shoot mainly :
- portraits in low-light venues,
- the occasional kid running around (in circle or on a bike
My lenses are either AF or old MF.
I often have to grab my camera and start shooting right away, so playing with settings are out of question.
So, I set up 4 USER modes (for the moment, still thinking about others).
All modes default to Auto-iso with a range of 80-51200, so I'm never rushed in full day with an high-iso value from the night before (done this once for an important pic!).
- Portrait (AF):
P mode (so I can set a specific aperture if needed)
Program Line set to "
DOF priority (shallow)"
Auto-iso set to "
Low" (roughly halves the iso used, so as to improve noise handling)
Drive mode set to "
Burst (Low)" (don't want to clog my HDD with identical shots!)
- Portrait (MF):
To be used for manual focusing, based on the same settings as above, but:
"Superimpose AF Area" set to No (I find these blinking red dots hugely annoying in MF).
- Action:
P mode (so I can set a specific Aperture or Speed if needed)
High-speed priority"
Auto-iso set to "
Normal"
Drive mode set to "
Burst (High)"
- Fast Action:
Same as above, but:
Auto-iso set to "
High" (roughly doubles the ISO used, and so the Speed!)
Feel free to give your own USER mode for your preferred shot type!
EDIT: Oh, and for a quick USER mode change, I find it easier moving the mode dial back and forth between USER and X than using MENU, down, OK, then choosing the USER mode I want (which is not named in this instance)...
That, or Off/On quickly...
The only gripe I have with this USER mode is that it won't let you create a Movie mode...
