01-20-2011, 01:28 PM   #1
Setting "exposure" for live view?
I'm trying to set focus manually ( at the moon ) by using live view, but the moon shows up as a white blob. Is there a way to manually set the "exposure" for live view?
01-20-2011, 06:21 PM   #2
Well, if you set a negative Ev comp, the live view takes it in account and darkens. But maybe it will ruin your shot? If you are in M mode, it won't bother you.
01-20-2011, 06:45 PM   #3
Center the moon in the frame and use spot metering (which you should be using for moon shots anyway). It will meter off the moon and the live view will adjust its gain accordingly. Any other metering mode will meter off the black sky and blow out the moon, both in live view and in the final shot.
01-21-2011, 12:34 AM   #4
I ended up using spot metering and it works as long as I keep the moon in the middle, but it moves and the exposure changes. (I'm in manual mode so the actual shoot is not affected). It won't work on a thin new moon though.
There is definitely room for improvements here.
camera, dslr, k-5, k-5 ii, k-5 iis, k5, moon, pentax k-5, view
Suggestion Can we add a setting to control the size of "Latest threads in which you've post"? Laurentiu Cristofor Site Suggestions and Help 2 11-21-2010 12:43 AM
Engadget: "Photography is dead, long live photos" emr General Talk 15 07-13-2010 03:49 AM
Digital preview: the poor man's "live" view joefru Pentax DSLR Discussion 2 05-19-2008 08:53 AM
Noise while "live view" is activated Ivo Pentax DSLR Discussion 4 05-03-2008 06:36 AM
Pentax K10D ISO setting "on the fly" tohcp Pentax DSLR Discussion 6 07-15-2007 06:23 AM
All times are GMT -7. The time now is 07:27 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
