Originally posted by Hound Tooth Clearly you haven't been reading some of the ludicrous theories being spewed forth by participants of this thread to explain the simplest thing in the world of photography: 1/3 stop ISO does not always equal 1/3 stop aperture does not always equal 1/3 stop shutter speed. There's nothing wrong with exploring this fact and learning from it, but going on tangents about CPU defects, A/C flicker and the way light waves bounce off walls due to the current rotation of the earth is WAY off base.
"There's nothing wrong with exploring this fact and learning from it..."
Exactly. So why the drama then?
The OP has observed something he didn’t expect. He’s the kind of guy that wants to understand why unexpected things happen, and in this process have done some (semi-?)systematic tests to figure out how the K-5 works.
And, that 1/3 stop ISO doesn’t 100% equal 1/3 stop speed does not seem like a fully satisfying explaining to why the difference occur between ISO 160 and 200 only, and only when D-rang is turned on.
A/C flick. Maybe it’s a stupid theory, I don’t know. But if someone
does knows better, then explain it.
CPU defects ??? No one said anything about CPU defect. Someone did say that "The in-camera number crunching ability is presently limited by cpu heat/size and battery power and not by cost." It’s a general statement saying that how much CPU power can be put into a camera (any camera) is not limited by cost, but by other factors.
This is a public forum where the level of expertise and knowledge varies greatly. Might be a challenge for experts to bear with the novices, but it would be a much better forum if experts (or is it "experts" ?) could explain things properly, instead of just putting things off as ridiculous.
