Originally posted by Ray Pulley The handle on the door to the right of the picture on the left is clearly the zone where the camera focused and it is well in front of the subject.Ray
Follow the door fame down to the floor and then use the floor line to keep you straight the door handle you mention bisects the ladies feet and is roughly in line with her knees.
She is stood stooped slightly backwards.
The shot is taken from 4-5ft and @f1.4 DoF is just under 1 inch !!
Even slight decentering in the lens would produce and image that looks like this.
Originally posted by Ray Pulley I fail to see how the wrong target was selected with the subject taking up most of the center of the frame,
I was being polite to the ladies dignity it is obvious on what the camera was focussed (look straight up from the agreed focal plane )
Originally posted by Ray Pulley but maybe the OP could chime in and explain how he focused on the door handle at the right edge of the frame.,
He didn't it happens to be the same distance from the lens as her feet,knees and other appendages.
Originally posted by Ray Pulley With no foreground, you cannot tell if there is signifcant FF on the right-hand picture or not.
Either way, as you say, the sharpening you applied to try and save the image is way over-done IMO, and looks terrible, also IMO.,
You can always tell if and image is focussed or just blurred.
Yes the sharpening was overdone as I used my normal profile for raw conversion and I always shoot low light with strong post NR so additional sharpening is required.
Yep it look terrible (especially the left one) but does show where the focal plane of the lens was and I see no FF in either image.
I could make comment on the IQ of the lens (left) but the is obvius to see and well know the fa50 doesn't cut it at f1.4 for short range portraits f5.6 or f8 would have been appropriate here.
