Closed Thread
Show Printable Version 11 Likes Search this Thread
03-09-2011, 07:46 PM   #31
alexeyga's Avatar
QuoteOriginally posted by areidjr Quote
Now I'm kicking myself. I bought the K-5 for a wedding I'm shooting on Sunday. After 3 copies with FF issues I returned it for a full refund. Now it turns out that if I kept it I'd have it for the wedding.
In any case, a few more good reports and I'll place an order for a K-5. It might be too late for Sunday, but I still want one.
And the best part is that the FF "issue" was irrelevant for the wedding since you'll be shooting during the daylight...
03-09-2011, 07:50 PM   #32
MrPetkus's Avatar
Thank you Pentax! No regrets sticking it out.
03-09-2011, 07:50 PM   #33
JayBee's Avatar
QuoteOriginally posted by nixifo Quote
Appropriate that nixifo be the one to break the news here!
And for all those (myself included) who commented on Adam's risking some credibility with his reassurances about the forthcoming FF fix - well, there you go - credibility confirmed. Enhanced even.
Now, just making sure my battery is fully charged before running the firmware update... (because, that would really suck!)
03-09-2011, 07:53 PM   #34
Surely there is something else on the K-5 we can now all find to meet daily and whinge and moan about?
It just wouldn't be Pentaxian like, to not find something of issue...
03-09-2011, 07:53 PM   #35
Christine Tham's Avatar
I hate to be the bearer of bad news, but I also discovered the fix is not perfect, and there is still FF in some situations.
I have just taken a number of shots, all on the FA43, f1.9, ISO100
Low level daylight, t=5s (EV -0.47): fine
Dimmed halogen light, t=10s (EV -1.47): fine
Dimmed halogen light, t=4s (EV -0.15): slight FF
Dimmed halogen light, t=1.3s (EV 1.47): slight FF
Dimmed halogen light, t=0.6s (EV2.59): fine
Halogen light (max brightness), t=1/4s (EV 3.85): fine
The degree of FF is less than before, but the camera is still not perfectly focused.
I'm happy to post some photos if there is interest, but I'm lazy and I'm hoping you will just take my word on it.
Bottom line: it's an improvement, but not perfect. Since I was pretty happy with the camera before, I'm obviously still happy with it, but ever so slightly disappointed that the firmware fix was not perfect.
03-09-2011, 07:58 PM   #36
QuoteOriginally posted by alexeyga Quote
And the best part is that that FF "issue" was irrelevant for the wedding since you'll be shooting during the daylight...
Umm, sorry, you're wrong about the quantity and quality of the light. Good try though There are both indoor and outdoor components to the wedding. The ceremony in indoor in a dimly lit church. The reception will be in the evening and also under dim light.
03-09-2011, 07:59 PM   #37
QuoteOriginally posted by Christine Tham Quote
Now I think you are just nitpicking!
03-09-2011, 08:00 PM   #38
Further addendum
Prior to Firmware 1.03, I was getting better results by disabling AF fine adjustment, and worse results if I enable AF adjustment but set global and lens specific adjustment setting to 0.
With Firmware 1.03, it seems there is no difference in behaviour if I enable or disable AF fine adjustment.
So this would imply if there was an issue with enabling AF fine adjustment, it is now fixed.
03-09-2011, 08:05 PM   #39
QuoteOriginally posted by ozlizard Quote
Perhaps.
But it seems the problem at around EV 0-2 is still there, just reduced in magnitude.
It's disappointing because the camera focuses perfectly at EV -1, but using the AF assist light.
03-09-2011, 08:07 PM   #40
MrPetkus's Avatar
The expected behavior would be:
AF fine adjustment disabled = AF adjustment enabled with 0 adjustment
If that wasn't the case prior to FW 1.3 but is the case now then I would consider that fixed.
Further addendum
So this would imply if there was an issue with enabling AF fine adjustment, it is not fixed.
03-09-2011, 08:08 PM   #41
QuoteOriginally posted by MrPetkus Quote
Sorry - it was a typo - I also consider that issue fixed.
Have now edited my post - apologies for the confusion.
03-09-2011, 08:09 PM   #42
Hey... That's an obsolete film lens. It's NOT digitally tuned. So what do you want... even the old stuff to work like new?
My gripe is that they did not fix the noise produced when shooting iso 51,200.
Silly me...
03-09-2011, 08:12 PM   #43
Bounce overexposure NOT fixed....
Too bad the bounce flash overexposure issue still exists. As an event/wedding photographer it kind of stinks. I wonder why this does not get the same amount of attention as the sensor stain or FF issues (maybe not a lot of pentax shooters use flash?). I have had 4 bodies that exhibit all the same behavior. For the people who aren't aware of the problem, set your camera on Manual, f4-5.6, 1/50th second, and any ISO (as long as the scene is not over exposed to begin with. For example, indoors at an event, I will typically shoot at f4-5.6,1/50 sec, and ISO 800 (to conserve flash battery power- at a higher ISO the flash will not have to work as hard)) and try using any flash bounced off the ceiling and compare it to direct (IN PTTL). The flash will overexpose by about a stop or more every time. The only way I have found to control it is to put the camera's highlight expansion on and to dial down the flash exposure -1/3 or -1/5. This is not a permanent solution because when I need direct flash, I have to fumble around to dial the flash up again. When I get some more time, I will post some comparison shots.
Eric
03-09-2011, 08:15 PM   #44
alexeyga's Avatar
QuoteOriginally posted by Michaelina2 Quote
Silly me...
You're not the only one... I kinda hoped for the " da masterpiece" shooting mode... didn't happen... damn!
03-09-2011, 08:15 PM   #45
QuoteOriginally posted by efkelly Quote
Eric
I never was able to reproduce that fault with the 3 copies of the K-5 that I had, all of which suffered from severe FF. When I get another K-5 I'll test it using your settings. I shoot a lot with bounce flash and also with large bounce cards.
Closed Thread
camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax japan, pentax k-5
Pentax Firmware Hack site tr13 Pentax DSLR Discussion 433 09-30-2014 08:59 AM
Firmware differences between US and Japan? bwDraco Troubleshooting and Beginner Help 1 11-18-2010 08:08 PM
K20D Firmware Ver - Pentax Web Site Ver? ChipB Pentax DSLR Discussion 2 02-23-2010 04:14 PM
Photo samples from K-7 Official Site Japan vizjerei Pentax DSLR Discussion 6 06-06-2009 09:26 PM
All times are GMT -7. The time now is 10:10 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
