03-28-2011, 09:17 PM   #1
Stop Down metering with K-5
Just received my new K-5 and am wondering how to enable stop down metering for use with my M lenses. With the K-7 one set Custom menu item 28 'Green button in TAV and M modes', but there doesn't seem to be a similar setting on the K-5. I'd be grateful for any advice.
Many thanks!
03-28-2011, 09:21 PM   #2
QuoteOriginally posted by jva59 Quote
Many thanks!
It's in the record menu now. Beyond that, it works the same way as the K7.
03-28-2011, 09:23 PM   #3
See here: https://www.pentaxforums.com/forums/pentax-lens-articles/110657-how-use-manua...7-k-x-etc.html
It should be the same option as on the K-5. Then, to meter, just pull the stop-down lever.
03-29-2011, 02:37 AM   #4
glee46's Avatar
See here: just pull the stop-down lever.
Could you explain, "Pull the stop-down lever" I couldn't find it with a search.
Is it on the lens?
Thanks
03-29-2011, 02:59 AM   #5
Ole
Ole's Avatar
QuoteOriginally posted by glee46 Quote
Is it on the lens?
Thanks
The lever around the shutter button. It has a position where is stops down the lens (if the appropriate menu setting is set to optical preview).
You can also hit the green button in M exposure mode if you want to meter and have the camera set shutter speed and aperture accordingly.
03-29-2011, 03:24 AM - 1 Like   #6
JohnBee's Avatar
Is it on the lens?
Thanks
03-29-2011, 05:52 AM   #7
QuoteOriginally posted by JeffJS Quote
Jeff,
Thanks,ubih but I'm not sure what the 'record' menu is.
Adam et al. I'll follow your lead, but is it possible to use the Green button system rather than the lever, which I got used to on my K=7?
Many thanks
03-29-2011, 06:08 AM   #8
Thanks guys,
Please ignore immediately preceding post. I've got it.
03-29-2011, 06:43 AM   #9
Just to clarify things a bit...
The Green button, in M, centers the meter by stopping the lens down for a period and setting the exposure time. Using the Stop down lever (AKA Optical Preview), with an M lens in M mode, will activate the meter and show it in the viewfinder. With an A type lens (F,FA,DA, etc) the meter is active for the length of time you choose to leave it active (mine is set for 30 seconds).
camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5
still don't understand stop down metering dh4412 Troubleshooting and Beginner Help 5 03-17-2011 05:43 AM
stop down metering? jonhock Troubleshooting and Beginner Help 8 01-01-2010 04:00 PM
K-x Stop-down metering with m-42 lenses Bazwell Pentax DSLR Discussion 8 11-20-2009 12:57 PM
*istD and stop-down metering pocky Pentax DSLR Discussion 6 06-20-2009 01:02 PM
stop-down metering and Av mode Beau Pentax DSLR Discussion 15 06-02-2009 09:58 PM
All times are GMT -7. The time now is 11:04 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
