A short review of the ExpoDisc in use with the K-5.
Info from the manufacturer:
ExpoImaging - ExpoDisc
I got this week an expodisc. That is a whitebalance disc that you put infront of your lens to set the whitebalance of your camera manual. There are different brands and also some cheep chinese knockoffs, who maybe work the same. I chose this one because I read some good things about it. It is expencive, 70 euro for the 67mm version (wich fits my 85mm and 50-135 and can be held infront of my other smaller lenses). I bought it to get some more controll off the colours out of my camera in sertain situations. Also because I sometimes want to shoot jpg's because K-5 isn't very fast with working the RAW-files in sports. Espescially in artificial lights the K-5 (and any other camera around) isn't that good in making a good whitebalance in AWB and thus producing good colours.
How thous it work:
You choose whitebalance (left on the forway steering) for manual whitebalance setting (In K-5 you can set 3 different whitebalance settings). You ame your camera with the expodisc infront of your lens (with the white creamy site to your lens) to the lightsource that is on your photographic object. Click the shutter, you will see a creme/blue/white-ish photo and choose too use the total image or only a part of it with the backwheel and click OK. You can adjust somethings in the settings, to warmer/cooler/yellow etc and press OK. This is your whitebalance preset. Don't forget in the menu to check the memory for whitebalance so your K-5 will remember your setting (is default). It is recommended to check if you did a good job on setting your whitebalance and if you have corrected for the right light-condition or that there is also another lightsource that is to be accounted for. Make a testshot and if nescesary do the test again.
Tricky:
The tricky part is to find the light that is falling on your photografic object and for wich you want to set the right whitebalance. Sometimes there are mixtures of different lightsources like in sportsarena's, or a combo of artificial and natural light together. It is a good thing to find out wich light is on your subject and wich whitebalans is important for you and where to compansate. In that case you can also aim teh expodisc with setting your whitebalans towards your photographic subject instead of the lightsource.
Whitebalance:
If your photolocation changes or the lightsituation changes your whitebalance will change also So this is not a fast way of working, but for a good chosen photographic work where you want to controll your colours produced direct out of your camera. Saving time in post-processing.
The test:
I did this test in the camerashop of Erwin, FotoLooman in Purmerend, where I picked-up my K-5 Silver. This test are the first shots I made with my Silver-baby. It's a shop in a Mall with no outdoors light and different light from the shop itself and from the promenade.
1) AWB
2) ExpoDisc whitebalans directed on the TL-light in the shop.
3) Same pictures as number 2, but with an adjustment to manual whitebalance of
A2, wich makes the colours just a little warmer
My personal preference goes to number 3, but maybe you look different to this with all your calibrated screens.
