Originally posted by macTak Thanks, JohnBee. I recall you being a fan of those Silicon Power cards. When tomshardware ran its big SDHC card test, they found the Silicon Power Class 10 card to only get 18.7 MB/s max and 10.2 MB/s min, rather less than the Sandisk extreme--with an off brand like that, you never know when and if they change suppliers such that the performance becomes lower.
Yes its true, and I vaguely remember that particular test.
However, I believe the test referenced was conducted with class 6 cards rather than class 10 ones.
Also, if memory served me right, the Silicon Power card proved to have sustained write speeds of 19.7 MB/s which was(at the time) considered top be the highest minimum write throughput of all the cards
And of course there is the throughput and read tests, but I never cared about those myself.
Having said that, They may have conducted some new tests since then(with class 10 cards?). But since my 32GB cards perform on equal footing to my Sandisk Extreme cards I never really bothered to look into it any further.
The only caution I'd advise to anyone looking for a bargain with SDHC's is to make sure you're not buying counterfeit products. They are quite popular on eBay and so I'd recommend researching the sellers prior to buying.
On a side note, I am somewhat disapointed that the K-5 will most likely not gain any read/write performances with the addition of SDxC Card support. Not that I needed this or anything(I find the existing buffer to be quite adequate) its just that it would have been nice to improve LV recovery times. - Again just very slightly disappointed
