04-21-2011, 09:57 AM   #1
Real life DR - K5 vs kr/kx
Any real life example of DR difference between K5 vs kr/kx
Yusuf
Update: DR - Dynamic Range
04-21-2011, 10:40 AM   #2
For starters, it is much, much quieter. The only real measure I can give is that with startup DR on, I've never seen a piece of dust on my K7/K5, whereas that wasn't the case for my k10 (which uses the same system as the kx).
It would be interesting to test this by pouring dust onto the sensor and then seeing how long it took to shake it off!
04-21-2011, 10:44 AM   #3
Send me you camera Adam... i'll test it for you!
04-21-2011, 10:52 AM - 1 Like   #4
johnmflores's Avatar
Are we talking Dust Removal or Dynamic Range? Or Dust Range? Or Dynamic Removal?
04-21-2011, 11:46 AM   #5
Dynamic Range I assume he is meaning
04-21-2011, 11:52 AM   #6
Dust removal of course- to test the dynamic range, just take a picture of a black dog- there are several here and there around the forum! Also, check dxo's charts.
04-21-2011, 11:57 AM   #7
Banned
QuoteOriginally posted by Ubuntu_user Quote
+1
Well If I look in DxO at the three current Pentax camera's in production (K-5, K-r and 645D) then it is clear that the K-5 has just over one EV advantage in average and a the biggest one from iso 80-250 that overclasses the possibility's from the two others.
DxOMark - Compare sensors
So you have to look at pictures in that aria where the total colourtone from black to white is used.
To my use I find DR-on starting at iso-160 with more room in highlights to work the best. No idea if this is even better in DR then iso-80 or just a shift or even a little less DR.
04-21-2011, 01:36 PM   #8
Rupert's Avatar
Curious.....I haven't read all the reports and most likely wouldn't understand them anyhow, but what ISO range would you use to get the best DR from the K5, assuming that was your goal in a particular shot?
What I am finding personally, is that all my Raw shots are processing much easier with the K5. Some lenses that were not allowing much pushing now appear to allow much better processing of images, easier and faster, with markedly better results. Anyone else notice this change? I don't know what to attribute this to, but I am seeing it every day in most all of my shots.....just easier and better results than I have ever seen before.
Some comments on the why of this would be informative, but I am pretty well satisfied with just having the great results, even if I never know why. I've already ruled out the outside possibility that all of a sudden I just became a better shooter or processor......I'm just old, not stupid.
Best Regards
04-21-2011, 01:44 PM   #9
Raffwal's Avatar
First definition for DR on my Google search was Disconnect Request, so that's gotta be it.
04-21-2011, 02:47 PM   #10
Good recovery, Adam
Serious, though, and DxO aside, if someone took a photo of a morning landscape, same lens, same low ISO settings, but once with the K-5 and once with the K-x/K-r, could a casual user see the difference? Could a pixel-peeper see the difference?
In other words, how does the DR advantage of the K-5 over the K-x/K-r manifest itself in real life?
And while we're at it, how good is the Dust Removal?
04-21-2011, 02:47 PM   #11
QuoteOriginally posted by Rupert Quote
Best Regards
Yup, you're not the only one. I've noticed this myself too!
04-21-2011, 07:36 PM   #12
QuoteOriginally posted by johnmflores Quote
Exactly, this is the question - interestingly I haven't seen any real life comparison.
04-21-2011, 10:08 PM   #13
Ash
Ash's Avatar
I can vouch for the phenomenal DR the K-5 has at ISO 80.
High contrast scenes are hardly a problem for it, notably recording shadow and highlight detail with more clarity than compared to both my K10D and K20D.
I can't give objective measures or post examples, but it's definitely no gimmick. The K-5 sensor's DR has real life benefits in photography.
04-22-2011, 12:29 AM   #14
Banned
I don't have/used K-x or K-r so no comparison. I did use K-7 so my world in DR got a little bigger with the K-5.
A picture with everything in it, taken with my K-5 Silver, FA*85mm at f2,2 and iso 100. With K-7 this would have lead to either black without detail, or white without detail or maybe even both.
04-22-2011, 03:23 AM   #15
Good recovery, Adam
I think it really depends on post processing. With the K5 there is an amazing ability to bump shadow content, almost up to HDR type levels, but just using a single file. With other sensors out there, there is just less information captured. At the same time, if you shoot jpeg and do no post processing, I bet the jpegs look pretty much the same if shot at less than iso 400.
camera, dr, dslr, k-5, k-5 ii, k-5 iis, k5, kr/kx, life, pentax k-5, vs
Real-Life FA*24mm Sharpness Torture Test Hello_Photo Pentax SLR Lens Discussion 8 03-21-2011 01:42 AM
Misc Some simple real life test shots with the Meyer-Optik Görlitz Orestegon 29mm/F2.8 Rense Post Your Photos! 14 02-09-2011 09:18 AM
Fear of SDM failure - a real life story Zorglub Pentax SLR Lens Discussion 7 02-10-2010 08:50 AM
Photos from real life wildman Post Your Photos! 13 04-21-2009 12:14 PM
some K20D ISO 6400 shots in real life situations Gooshin Pentax DSLR Discussion 10 07-06-2008 06:09 AM
All times are GMT -7. The time now is 05:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
