Originally posted by A440 So, I've been browsing the forum trying to get some insight as to which lens or lenses I should get when I buy a K5.
It will be my first DSLR. For the last few years I've been mainly shooting a rangefinder film camera with a fast 35mm f1.4 prime, mostly B&W iso 400. So used to shooting easily in available light with high IQ. I've also been using an LX3, which is a great pocket camera.
As I'm getting into DSLR's I'd like to consider zoom lenses but have little experience with them.
From reading around about the 18-135mm WR would seem like a good place to start, however there does seem to be a fair amount of criticism aimed at it. Is it really as bad as all that?
For example, I could buy the 18-135mm and a couple of primes...perhaps the 21mm Ltd and 35mm Ltd...Or instead go for the DA* 16-50mm & DA* 50-135mm ... which have a good reputation, especially if you get a good copy it seems, but may be a bit heavy?
Anyway...there's a lot to choose from and I'd be grateful for any input.
If you are shooting B&W ISO 400 with a 35mm f/1.4 I would first get a prime that is fast and works for your style of photography. K-5 is a pretty serious tool and a big step up.
I would recommend a K-7 for the price it can not be beat, and is still a step up over what you have been using.
The 21mm and 35mm are both excellent lenses, but I would go for something faster.
The Sigma 17-50 f/2.8 OS HSM is a better lens than the Pentax version, is cheaper, focuses faster, & has a better warranty.
Tamron 70-200 f/2.8 would be my choice over the 50-135mm. Not the exact focal length, but again the Tamron is cheaper, has more range, a better warranty, & sharper.
The DA 12-24 f/4 might be a good choice if you like wider glass, but is is only f/4.
I personally always buy glass over bodies, as bodies are always dropping in value.
