Show Printable Version 399 Likes Search this Thread
04-13-2018, 11:44 AM - 2 Likes   #1081
K-5 at ISO 80 : Very Best APSC Sensor 4 Long Exposure
QuoteOriginally posted by gbeaton Quote
... you can get Pentax and other sensor data here: Sensorgen - digital camera sensor data
You've had a good idea, gbeaton !... I already know Sensorgen.info, but...
it reminds me a nice way to understand how easily the K-5 detects very faint lights at ISO 80 !
Sensorgen calculations from DxOmark Full-SNR
Open the K-5 in DxOmark Database
- Open it in a New Tab at Measurements / Full-SNR tab...
- Open the Eos 7D & Eos 1D Mk IV at Measurements / Full-SNR in 2 more Tabs
the 3 Cameras Sensor I've compared in 2011
Everything you need to know about a Camera-Sensor's Behavior in Low-Light is here
Let's Compare their Detection Threshold at -1) base ISO -2) ISO 1600
Base ISO Detection Threshold - PK-5 0,008% - C1DM4 0,036% - C7D 0,045% of Gray Scale
ISO 1600 Detection Threshold - C1DM4 0,097% - PK-5 0,109% - C7D 0,193% of Gray Scale
=> Pentax K-5 is far more Sensitive at Base ISO than a Good & Expensive Canon PRO cam.
Subtracting tens of Bias-Maps & Dark-Frames from the Eos CR2 files will lower their Noise
but they will Never Detect 0,008% Gray Details unless you Stack tens+tens of RAW files
while Pentax K-5 and its Very Low Noise only needs from 3 to 6 RAW files at ISO 80
Don't forget final results are worse than theory, Canon Banding is Not Measured :
https://en.astronomike.net/deep-sky/nebulae/162986.html
The Eos 1D Mk 4 is slightly more Sensitive than the Pentax K-5 at ISO 1600
ISO 1600 difference could be worse if shooting with Newer Canon cams
3 Re-Scaled DxOmark Full-SNR Charts Comparison posted in 2011 :
Pentax K5 vs Canon 7D : comparaisons et raisons
Re-Scaled DxOmark Full-SNR Charts with base ISO & ISO 1600 Detection Thresholds :
04-18-2018, 05:07 AM - 4 Likes   #1082
Long Exposure @ Base ISO : a Pentax K-5 !... what else ?
To answer the "what else" question, I summarized :
- the Top-8 Cameras with lowest Detection-Threshold < 0,01% @ 0dB SNR, from DxOmark
same as in my previous post, ordered by Measured-ISO
- the Top-8 Cameras with lowest Noise-Levels in 5 min. Dark-Frames
from The Sensor Noise DB. – Brendan Davey Photography
ordered by their Noise-Mean-Value
Pentax K-1, the 95 Top Measured-ISO with a Detection-Threshold of 0,009% @ 0dB SNR
+ the 2nd Noise-Mean-Value just behind the Pentax K-5 in 5 min. Dark-Frames (+5ev)
The very Low Dark-Current levels of the Sony imx071 explain the Pentax K-5 Top position
= the 1st lowest Noise-Mean-Value in the 5 min. Dark-Frames (+5ev) test
the Dark-Current Chart is from the Zwo Astro imaging site :
https://astronomy-imaging-camera.com/products/asi-cooled-cameras/asi071mc-pro/
Same Sony sensor, at a $1700+ price !
Then the Asi071(K-5) compared to the Asi294 and Asi1600
= two Astro-Cams with 4:3 ~22,7mm diagonal sensors
High ISO settings are mandatory to lower the Exposure Time to 1 sec. or less
this to cancel the Atmospheric Turbulence effect with long FL.
the only way to operate with Lucky Imaging !
But finally, what do you lose from Base-ISO to ISO 10K :
- Dynamic Range value from 14 ev down to 7 !
- Tone Values from 16384 down to 128 !
- SNR to be Half the Base ISO SNR
- your RAW File Size doubles
- for the same final IQ, you'll have to Stack much more RAWs...
- with Dark-Frames !
06-19-2018, 09:11 AM - 8 Likes   #1083
Eagle Nebula and Lagoon/Trifid Nebulas with Webb's Cross
I had the IR-cut filter and anti aliasing filter removed a couple months back, and now have a capable astronomy camera with a bare sensor. I think it was about $250 conversion at spencer's camera, and is now a capable atro-photography camera.
The Eagle Nebula with the Pillars of Creation in the center I shot 90 lights and 30 darks at 45-second exposures and ISO 400 with my Skywatcher Maksutov-Newtonian 190.
The Lagoon/Trifid Nebulas with Webb's Cross in the top right corner I shot 90 lights and 30 darks at 30-sec exposures and ISO 400 with my Takahashi FSQ106ED.
06-19-2018, 10:57 AM   #1084
Pete_XL's Avatar
QuoteOriginally posted by Eric Seavey Quote
Congratulations Eric! They did a good job obviously
07-11-2018, 01:48 PM   #1085
Location: Milky Way Galaxy, Planet Earth, Speeding towards the Virgo Supercluster
Those results now have me really considering getting the recently aquired "slightly used" K-5 I grabbed from Adorama modded. Being on the fence has now become to almost the jumping off point. I don't have the cam in my possession as of yet though..
08-26-2018, 06:58 AM - 1 Like   #1086
After reading through this thread, it got me interested in seeing what my K-5 could do last night. Considering that it was unmodified and horrible astronomy conditions with haze, cloud and the night before a full moon; I'm actually impressed with what it was able to do with my 28mm @ f2.8 & ISO 1600 with a 20 second exposure. It's enough to make me wonder if I should go after a faster 28mm.
08-26-2018, 03:12 PM - 1 Like   #1087
QuoteOriginally posted by DrMindbender Quote
Until you decide what to do, here is a slightly different approach. You can stack any number of images, which would combine all the captured light together. Just aim the camera to the sky and take multiple images. It would be better to have the mirror up and just put the body in burst mode. I would probably go with 10 second exposures to keep the star trails at a minimum.Then use a program like sequator (free download), to align the images together and then stack them.
08-26-2018, 06:17 PM   #1088
QuoteOriginally posted by interested_observer Quote
Thanks for the pointers. Fortunately, or unfortunately, I'm in no rush to do anything other than aim up and shoot thanks to the full moon. So it will be a few days before I try the "burst and stitch" method.
09-28-2018, 02:55 PM - 6 Likes   #1089
Here another couple shots taken with my modified K-5 camera... Helix Nebula and Comet 21P Giacobini/Zinner in conjunction with Messier 37
09-29-2018, 04:00 AM   #1090
Pete_XL's Avatar
VERY! nice, Eric! Congratulations!!!
09-29-2018, 07:22 AM   #1091
Visually stunning, Eric. I particularly like the comet and the star cluster. Nice colors in the Nebula. Very well done. If you already haven't done so -- you should cross-post the images over on the CN digital photography forum -- just to show those guys the capabilities of a Pentax camera.
12-11-2018, 04:48 PM - 4 Likes   #1092
I shot another comet last weekend.... 46P/Wirtanen. This one appears really large (much larger than the moon), even though the actual comet is quite small. I shot this with my Takahashi FSQ106ED scope and my Pentax K5II.
01-05-2019, 05:15 PM - 1 Like   #1093
Hi everybody!
I just set aside my infamous k-50(pentax the red) for a K5 I won at auction and I'm currently working on getting things ready to try it out in the coming weeks.
I felt pretty good reading the last few pages of this thread after that initial effort to get tethering working better, despite being left hanging by Ricoh and the k-50's flaky firmware. The credit for getting it working goes to András Salamon of
Pktriggercord and especially the very busy Marcus Meissner of LibGphoto2. After hacking on source from both projects on my own, I had the idea that maybe Marcus could look over András' work and update the pentax section of Gphoto2. Marcus took interest in the project and made a wrapper to combine PKtriggercord with Gphoto, without having a Pentax camera on hand, by having me recompile and test each iteration until we got it going*. He did eventually get a k10d to work out the bulb command since mine was broken and no other testers had stepped forward.
I'm also glad to see discussions of Indilib/Kstars as well because it was that full on AP suite that made me want to tether the K-50 in the first place and Jasem Mutlaq has built a great group of guys supporting the project. The key point I'd like to make while I'm blowing the horns is that these guys are all Opensource developers motivated by a need and sense of community. They might not say they all run on hugs but they do...and a tip in the beer jar here and there helps too.
Support your opensource heroes!
P.s. some great looking photos here too
03-26-2019, 08:07 AM - 4 Likes   #1094
PhotosbyV's Avatar
I love doing astrophotography! Living in the east makes finding suitable dark skies very difficult. My cold intolerance makes winter skies a no go for me. Now that spring is finally arriving, I'll have more chances to get out again.
I have found that exposures longer than 20 seconds has left trails with my K5.
Here is one of my favorites taken at my brother in law's farm in Northeast Iowa.
PENTAX K-5  Photo
03-26-2019, 09:20 AM - 3 Likes   #1095
Pete_XL's Avatar
QuoteOriginally posted by PhotosbyV Quote
This is a really nice and scenic image with the Seven Sisters perfectly captured! Concerning the trails you might want to stick to the "Rule of 500" to avoid them. The exposure time should be shorter than tmax = 500/(fl x crop-factor). So with your 18 mm lens and the K5 it definitively should be shorter than 500/(18 x 1,5) = 18.5 s. I tend to use a "Rule of 400" instead to have a safety buffer.
activations, angle, camera, dslr, flickr, gps, images, interval, k-5, k-5 ii, k-5 iis, k5, lake, leds, lens, pentax, pentax k-5, picture, shutter, sky, star, thanks, time
Astrophotography iClick Pentax DSLR Discussion 1248 12-19-2021 05:07 PM
Astrophotography with Kr??? kooks Pentax K-r 5 04-23-2011 07:12 AM
Astrophotography Naturenut Troubleshooting and Beginner Help 4 09-09-2010 07:27 AM
Astrophotography with K10 J-Rod Photographic Technique 5 12-12-2009 06:08 PM
K7 And Astrophotography Christopher M.W.T Pentax DSLR Discussion 49 11-25-2009 08:51 AM
All times are GMT -7. The time now is 08:52 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
