Originally posted by holycow hi,
i've noticed these spots on my photos that only appear at f11 and higher; are they dirt or are they stains? i've used the pentax sensor cleaner to try and remove them but they remain.
this photo is at f22 and is a crop
serial number is 3934419
Hi
If you cannot remove these dust spots (believe me they are dust) with the PENTAX dust removal tool then they have already bonded to the filter surface. A wet clean is required and to judge by the intensity of their appearance in your picture they will come off with the wet cleaning procedure.
This dust has probably been ignored for too long. Please bear in mind the offending particle could be, among many other things, of a ferrous nature. Now with a bit of humidity and (depending on the volume of the speck measured in microns) the ensuing oxidization that will then take place will make bonding a very rapid process.
In other words, the dust sticks to the sensor (filter) surface more then the sticky lifting force of the PENTAX lolly can provide. (Not to mention a blower)
Greetings
