05-27-2011, 07:34 AM   #1
Deiberson's Avatar
X Sync Socket
Not sure if I should post this in here or the lighting forum so I might double post.
If have a pair of Adorama 620 Mono lights. They came with the sync cord. Is this cord just used to fire the lights or......will it carry the TTL info into the mono lights from the camera? I always assumed that I have to shoot the mono lights in manual via the speed dial.
I'm also assuming that I have to fire the 2nd mono light and whatever other speedlights that I have as a slave since I can only have 1 cord....correct?
Thanks
Kevin
05-27-2011, 08:28 AM   #2
Yes, you will have to shoot in manual. Yes, you will need to trigger the other monolights with slaves or get a splitter for your sync cord. As long as you are not shooting around other flashing lights the optical slave trick works just fine.
camera, cord, dslr, fire, k-5, k-5 ii, k-5 iis, k5, lights, pentax k-5, post, sync
x sync socket Chuckster Pentax DSLR Discussion 0 02-17-2011 08:01 PM
Outrageously expensive X-Sync socket caps... any other source? Timichango Pentax DSLR Discussion 9 07-21-2010 03:30 PM
x socket problem vamountainman Pentax DSLR Discussion 2 03-10-2010 04:27 PM
K20D flash sync socket problems flexidan Pentax DSLR Discussion 2 10-24-2009 04:19 PM
PC sync socket on K20D Anya Troubleshooting and Beginner Help 6 05-15-2009 08:28 PM
All times are GMT -7. The time now is 03:34 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
