I have two K-5's now. One, the new one as my main shooting camera now and one as a back up.
My concern is the build quality? I am a wildlife shooter and am starting to get kind of concerned. The first one has serious shutter problems. First with an occasional freeze up. To now happening 10 times a day in MY normal use. 100-1000 shots a day. All high speed shooting bursts of 3-10 per shutter release. At first with a battery change or a quick off and on to now almost utterly useless. It is an easy field fix. Of now taking it off the lens and now lightly smacking the side of the camera. This is my second post about this and am more curious than anything about heavy use of the Pentax K-5. I used the K-x with not problems at all befor the K-5.
Now with two weeks on the new unit it is showing the same signs as the first. Occasionally a freeze up.
In BKK at the pentax service center in a fairly relaxed talk the Tec. said forget it. It is a no fix. All have the problems at this level of use. Now I am insisting on a repair of the first unit now. It is going back. So I hope problem solved with it for a while. But with the second unit showing early signs of the problem it is rather disturbing.
Question? Do any of you guys shoot very heavily with the K-5. Say a demanding semi pro level? And if so do you have any quality issues.
Thanks
