06-21-2011, 06:43 AM   #1
Clavius's Avatar
Overexposure with fast lenses
Here's another newbie question for you guys!
I've noticed that my K5 works very well together with my slower DA lenses. My kitlens, my DA 16-45, DA 10-17 and the DA 55-300.
Strange thing is, with my faster lenses, the FA 50 f1.4 and the DA 35 f2.8 ltd, it suddenly overexposes.
I've been correcting his issue by adjusting the EV compensation to underexpose -1 and even -2. Only then correctly exposed pictures appear. This solution feels a lot like chimping. Which it is, I have to take a picture first, see what it looks like, and then adjust the EV compensation and take a corrected pic.
Please tell me what I'm doing wrong here.
06-21-2011, 06:52 AM   #2
Does it happens at all the apertures or only at faster aperture? Have you fixed your ISO at higher value? It's possible that light is strong enough and shutter speed is not able to match it.
06-21-2011, 07:04 AM   #3
Clavius's Avatar
QuoteOriginally posted by yusuf Quote
Thanks for you quick reply.
Yes, it happens at all apertures. Also with pictures where the shutter speed is easily able to match. Like 5.6 / 300sec / iso 200.
What do you mean with fix the iso at higher value? I did activate the iso noise reduction in the higher iso's yes.
06-21-2011, 07:32 AM   #4
He means, are you taking photos at an ISO that is higher than needed? A few more details and even photos (with EXIF in tact) would probably help. Such as, what mode are you using?
06-21-2011, 08:05 AM   #5
QuoteOriginally posted by Clavius Quote
Nevermind, I was just wondering if ISO is too high that causing even highest shutter speed to be insufficient (often happens with me when I forget to reset ISO after night shooting).
Since this is not the case with you, you might want to share a few more details like mode, sample pictures.
06-21-2011, 08:34 AM   #6
Banned
Well some lenses just need a little adjusment and some don't. Part of learning equipement.
06-21-2011, 09:39 AM   #7
I've never tired FA50 1.4 myself, but my FA31 overexposes about 1.5EV. Other fast lenses I've tried (FA43, FA77, DA*55) seem just fine. I've tried 3 different FA31s, and they all overexpose the same amount. I guess it's lens and body combination issue. It's easy to adjust, so no big deal.
06-21-2011, 09:49 AM   #8
Clavius's Avatar
QuoteOriginally posted by MaK5 Quote
Ok, just wanted to make sure it wasn't incorrect settings or something.
Thanks everybody!!
06-21-2011, 07:44 PM   #9
Smeggypants's Avatar
I have a FA50/1.4. It doesn't overexpose on my K-5s
06-22-2011, 01:30 AM   #10
My K5 also overexposes with my 31 Limited. At first I was a bit surprised, but then it is easy enough to adjust.
06-22-2011, 01:31 AM   #11
Sticky aperture? Try at wide open, f1.4. If it exposes correctly wide open, it might be a sticky aperture. Maybe the K-5 wants to actuate the aperture faster than its predecessors (speculation).
Sincerely,
--Anders.
camera, compensation, da, dslr, ev, k-5, k-5 ii, k-5 iis, k5, lenses, pentax k-5
K-X stop down metering problems with fast lenses i_trax Pentax DSLR Discussion 3 07-27-2011 06:00 AM
Why no fast Pentax lenses? Framed Pentax SLR Lens Discussion 54 01-01-2011 08:24 PM
Fast (f/2.0 or greater) Macro lenses available in Pentax K mount? Edgar_in_Indy Pentax SLR Lens Discussion 37 12-09-2010 09:17 PM
I want some light, sharp, fast prime lenses...hopefully I came to the right place innocent smith Troubleshooting and Beginner Help 15 04-21-2010 02:51 AM
Pentax - where are the fast lenses?! Spock Pentax SLR Lens Discussion 94 11-04-2009 08:09 PM
All times are GMT -7. The time now is 03:59 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
