Originally posted by Nicks I have to adjust the AF to different values almost every time I use the lens. The last value I used is still there when I mount the lens, however the focus is not good for that value anymore. Before the last firmware the AF was set at -4 and it was perfect every time. Now I'm going from -7 to +5.....so random.
Wow that really sucks!
If it means anything to you, I once owned a D200 with a Nikon lens that had to be sent in three times for calibration. After which is still wouldn't keep focus. I finally gave up and set the lens aside until I ended-up selling the unit.
I guess on the bright side, you can(at very least) calibrate your lens rather than having to send in the entire unit until a fix is issued.
