07-13-2011, 06:44 AM   #1
wishlist: additional E-Dial options in Manual mode
I use Manual mode a lot, and have been noticing the conspicuous absence of several useful e-dial combinations.
Please post your opinions.
E-Dial Programming - Manual mode - Dials
Tv / Av (existing)
Av / Tv (existing)
Tv / ISO <- want!
ISO / Tv <- want!
Tv / +-EF <- want!
+-EF / Tv <- want!
And in addition to the existing Green Button options, I would like:
ISO Shift
If you are using:
-a catadioptric (with a fixed aperture)
-or an M-series lens (with an aperture bezel on the lens but no electronic coupling)
-or an A-series lens not set to 'A' on the bezel
-or anything mounted in reverse or on extension tubes
then the dial that has Av bound to it becomes completely useless. There needs to be options to combine EF and ISO into the mix of possibilities.
eg: Manual mode - Tv as rear dial, and ISO as front dial.
...but I cannot do this at all under firmware K-5 v1.10
av, camera, dslr, e-dial, k-5, k-5 ii, k-5 iis, k5, mode, pentax k-5, tv
Mode dial lock in k-x - possible? yusuf Pentax DSLR Discussion 3 05-28-2011 11:18 AM
Help! Mode Dial stuck? chriiisty Troubleshooting and Beginner Help 6 03-14-2011 01:05 AM
k200d mode dial help!? MoeRoadKill Troubleshooting and Beginner Help 8 01-20-2011 05:20 PM
Dial mode not work JoZ3 Pentax K-r 3 12-26-2010 06:27 AM
Mode Dial Question pomegranate Troubleshooting and Beginner Help 3 12-04-2010 12:50 PM
All times are GMT -7. The time now is 08:52 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
