Originally posted by citrus sky Thank you everyone.
JeffJS, how do you view the raw files as thumbnails in explorer? I take alot of photos and sometimes take RAW+ just so I can preview the jpegs in explorer but it takes up alot of SD card space so this would fix that.
Does anyone use lightroom? pros/cons over using PS5?
It is probably the little 'side car' files that show in explorer. However, if I try to View the PEFs, I get an error message that the file is broken somehow (paraphrasing). A browser that works however, is FastStone image viewer if you want to be able to look at the RAW PEFs full sized. I think IRFranview will also do it as well as a couple other freebies out there. I use RAW+ for the same reason, so I have a JPG to see what is there.
I never really warmed up to Lightroom. A lot of things I do require layering which, to the best of my knowledge, Lightroom does not do. It is a good piece of software but I've always considered it more for cataloging than post processing (which it does both quite well IIRC). I just never really got use to the user interface of LR and have been using PS since version 4 (not CS4).
