Originally posted by daacon What metering are you using ? Are you suing af.s or af.c ?
About the metering I'm using the full one (I think it's the 16 segments). And for the focus I'm using both but I've found that the AF-C is too slow! So I use the the AF-S and I'm following the subject and pushing multiple times the AF button while the action is moving.
Originally posted by crewl1 Are you using the AF center point focus only? When I shoot sports using AF-c I notice that my out of focus shots are generally because I did not have the center of the frame where it needed to be to get the focus I wanted to achieve.
About the focus point I use the "selectable one", where you can select your point. But must of the time it's the center point.
Originally posted by crewl1 Your gallery looks very good. Are there any problem shots you want to point out? The ones I looked at are nice.
Here's an example :
http://www.actubdl.fr/IMGP1393.JPG (Warning: it's the original size!). The board is ok while the player isn't.
