Originally posted by Ash Even in multi-segment metering can a scene be overexposed by the K-5 - it all depends on composition and meter-locking mode (do you have it linked to AF point and/or locked at focus confirmation?)
Essentially, if you want to avoid blowing highlights in high contrast situations, you'd spot meter the high key area, or centre-weight the scene and dial EV down to -0.5 or -1.0
Up until the K5 (I have little experience with the k7) the Pentax metering was very much in line with traditional metering and consistent with the other Pentax cameras I have used for many years.
If a scene had significant white areas or if I spot-metered on white, I would dial in somewhere near +1.5 stops of exposure compensation. Some lenses were a bit different than this (my 31 ltd, for example needed more + EV comp). Similarly, blacks required a similar amount of minus EV comp. This was just as it should be based upon the normal metering calibration that has been around for decades.
Frankly, I have no idea what the K5 metering is up to in many cases. Overexposing scenes with significant bright areas makes no sense to me. Maybe there is some logic to what the multi-segment metering is doing in these cases, but just as with P-TTL, Pentax isn't telling.
Ray
