09-28-2011, 04:28 PM   #1
A little advice? SR working?
I am playing around with the K5 which I bought used. Now I am one to blame user over machine 9/10 times but take a look at these pictures. Please tell me where I am messing up. I would normally sit down and just RTFM and play around, but I only have so long to complain if there is reason to complain.
These results are easily duplicates
Both shot at ISO 1600 55m F4 1/10
Now I am a shakey individual and it shows here. SR off
So I should turn SR ON, But I get this
As I said this is easily repeatable. The symbol for SR is showing in the viewfinder, in Fact on this one I counted to 5 before snapping. Please tell me I am doing something wrong!!
09-28-2011, 04:49 PM   #2
Ex Finn.'s Avatar
Just to check, 1st is with SR off, hand-held and second is with it on hand-held? In that case it could be broken. Unless the lens information did not register with the camera.
09-28-2011, 04:50 PM   #3
EX Finn - Correct - Even though it is showing the correct focal length (55mm) in lightroom it is saying the lens is the sigma 70-200 (I am using the sigma 24-70). Is there something I can do to manually change that?
09-28-2011, 04:58 PM   #4
Looks to me as if the switch has reversed positions. That "SR On" shot is exactly as it should look for a normal person without SR on at 1/10 second.
Jack
09-28-2011, 04:59 PM   #5
Ex Finn.'s Avatar
QuoteOriginally posted by rkboid Quote
Someone using that lens might be of better help, I only have/use Pentax lenses.
But sure looks like the SR is over correcting for the glass.
p.s. Only time I can manually enter the focal length is when using old manual glass or telescopes and the cam powers up asking for the focal length. If there is a way, I never crossed it.
09-28-2011, 05:10 PM   #6
Ex Finn.'s Avatar
Wait, how about with a different lens, have a kit 18-55 by any chance.
09-28-2011, 05:16 PM   #7
unfortunatly no lens until my 16-45 arrives.
09-28-2011, 05:20 PM   #8
My three suggestions:
Yeah, try another lens if possible.
Mount it on a tripod and then try both with SR and without.
Try different settings, e.g. f/2.8 ISO 1600 1/20
Keep trying different combinations until you can completely pinpoint what exactly is going on. Of course, we're here to help!
09-28-2011, 05:20 PM   #9
Ex Finn.'s Avatar
I am out of ideas, time for someone smarter to chime in.
Cheers, Mike.
09-28-2011, 05:33 PM   #10
It does happen at all settings except when my shutter speed is fast enough (DUH, lol). Anyway I really can not do further tests until my new lens comes in. Until then I will most likely start another topic to see if there are any users with this combination and see if thier K5 properly identifies it. My guess is that is the problem, but now have to figure out if it is the body or lens. Thanks everybody.
09-28-2011, 05:57 PM   #11
Aegon's Avatar
If you are using the 24-70 and it is registering as the 70-200, then presumably the camera thinks you are shooting somewhere between 70-200 and providing SR for the incorrect 70-200 focal length. If so, then the SR would be all wrong for an actual focal length of 24-70.
Searched:
https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/154311-shake-r...dg-hsm-k5.html
In the above-linked thread, Frank says "Called our Sigma service center just now, they can rechip the lens for me". You should probably do the same.
09-28-2011, 06:00 PM   #12
Yeah, that is true, but the focal length is actually correct (55mm). Would that make a difference?. I do agree with you however and think that is the root of the problem. Do you think that is body or lens related problem?
09-28-2011, 06:46 PM   #13
OK search function does wonders
Seems it is a problem with the sigma lens firmware. A member posted back in August about this very problem. Of well I guess the lens is going back, becasue there are no sigma centers close to me.
09-28-2011, 07:10 PM   #14
dms
Try on tripod with sr on to see if the sr is adding motion--even if it has wrong focal length seems like it should add very little--if it adds lot of motion likely camera problem. If you lens has aperature ring put it in non A position and input focal length. If not then insulate contacts (presume it will think it is a K lens) and input focal length and let camera take photo wide open.
09-28-2011, 07:10 PM   #15
Yes, it definitely makes a difference, the longer the focal length, the more the camera has to move the sensor in order to compensate for the shake. If it think the focal length is 150 and it is really 55, you will get a mess (as you did).
camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5, sr
Macro I'm Working! eaglem Post Your Photos! 3 05-21-2010 07:37 AM
K-X sr working? bullwhip Pentax DSLR Discussion 6 01-20-2010 12:44 AM
How to tell if SR is working? slow2focus Troubleshooting and Beginner Help 14 12-21-2009 09:49 PM
survey: batteries working/not working with the K-x noou Pentax DSLR Discussion 25 12-03-2009 02:43 PM
Advice Columnist Advice on Photography - do you agree? betsypdx General Talk 9 06-24-2007 12:45 PM
All times are GMT -7. The time now is 06:52 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
