Originally posted by tx0h hi,
solder a 1k Ohm resistor
between trigger / middle
contact and flash mainboard
connector.
in the picture:
Resistor Color Code:
brown black black brown
with 1% tolerance (brown)
please send fail or succeed
stories.
thanks,
tx0h
warning, this will break the warranty and may damage equipment, this is a standard disclaimer and you really can't blame me if somethings get broken.
Hello:
I also had the problem of freezing, of my flash Yongnuo YN-560 when placing it in the shoe of my PentaX K5-II.
Luckily I fell on this page and I could find the solution to the problem, I have soldered the resistance of 1 Koh and for now, after several tests, everything works correctly.
A few days ago I contacted Yongnuo to explain the problem and although they were very kind, they could not give me another solution other than to open the battery compartment and close it again, which is not exactly a solution.
Thank you all for the contributions that have led to finding a solution.
I would also like to know, if those who have soldered the resistor, have encountered some problem of operation of the flash unit or the camera.
Thank you and have a good day.
