Originally posted by pentaxgrl Highschool gyms what i want to shoot in and football fields... I was trying out some settings in tv mode.. useing a promaster 70-300 mm so if I'm setting in a gym my daughters basketball game what settings would work without useing the flash. I was experimenting by turning the dial to user then in my menue turning it to tv and trying different apertures couldn't get anything good. allot of darkness.. what would work best for indoor action? I'm a total ameture when it comes to action. here is what kind of photographer i am
Welcome to Facebook - Log In, Sign Up or Learn More I think im pretty good at what i do. but i think my action needs ton of work..
I'm no expert at it but what I would Try is this.
Set Tv mode front dial (or rear) to control EV Compensation and dial it to about -1 if the uniforms are dark, +1 if they are bright (white).
Center Spot focus and spot meter
Auto ISO with a limit as high as you're comfortable with
Pick a shutter speed that doesn't peg the aperture wide open
Fire away. You'll know within a few shots if you're getting what you want. You can then thank me for the advice. If the advice fails, I'll gladly accept an e-slap across the back of the head
