But what is it exactly that you want to change when you change ISO? If you want the shutter speed to change, then you can use aperture priority. If you want aperture to change, then use shutter priority. With either one, you can set ISO where you want, and one other (non-priority) setting will change to compensate. But really -- in manual mode, how is the camera supposed to know which setting you want to change (shutter speed or aperture, or some combination of both?) when you change ISO? The only way it can is if you use the green button, and you have to decide in advance whether you want the shutter speed or the aperture shifting.
I'm not sure what you mean by "follow your setting for the green button," but you can set the green button to give you Program Line, Tv Shift or Av Shift.
How does the meter "mess with you" in the other modes? I'm just curious.
