In continuous shooting, your burst rate will slow down if:
- you have in-camera post-processing incl. lens distortion correction, high ISO correction, ....
- your buffer is full, or
- your card is too slow.
I do a lot of long hi continuous shooting, My experience suggest that:
- you must kill off all in-camera PP
- you must use JPEG for long sequence (simply because the buffer output rate cannot cope with RAW files at 5-7 fps (
*)), and
- you must use a Class 10 card or faster.
Note: (
*) A PF member measured the burst rate of the K-5 and find that it is often between 5 to 6 fps, shower than the official 7 fps. I measured myself the burst rate of the K-7 and I get between 5 to 5.2 fps.
From your description, I would say:
- you be better off to switch to JPEG for shooting continuously;
- get a fast SD card;
- after each sequence, wait until the shots are all written to the card and switch off any LCD preview.
Hope that the comments may help.
