Originally posted by Big G It's not just about the resolving power of the lens, but the whopping gaps in the Pentax lens line up not to mention well-documented SDM problems and noisy screw driven models is what gives Canon and Nikon the edge.
I've said this before; it all depends on what you want / need from a camera system. Some of the Canikon primes are absolutely unbeatable in terms of flexibility and resolving power, particularly on full frame. The 17mm TS and 24mm TS have virtually no distortion, some of the best resolution figures I've seen and the ability to correct for tilt distortions in lens which makes them two of the best landscape lenses available. Regarding other primes, the 14L, 24L, 35L, 85L, 100L, 135L and 200L are also awesome; although the 85L at less than f/2.8 on full frame isn't so good in the corners (you'd be bokeh'd out anyway).
Just to reiterate however, it all depends on your needs and requirements as a photographer
I don't particularly see Pentax's lens line up as lacking, except when it comes to telephotos longer than 300mm. The only lens you mention as faster in Nikon's line up isn't in Nikon's line up, it is a third party lens (granted not available for Pentax
). Still, for how many people is the option of buying a tilt shift lens really that important?
As to the noise of screw drive, maybe I'm old school, but I don't mind it at all. Nikon has plenty of older, screw driven lenses as well. People who buy them do so because they love the optics and also, because their longevity is nearly guaranteed to be quite a bit longer than a lens with an in-lens motor. It also allows for the lens to be made much smaller. Just look at the comparison between the Canon 100mm IS f2.8 macro and the Pentax DFA 100 mm f2.8 macro WR. The Canon weighs in at 625 g and has 7.7 by 12.3 cm dimensions. The Pentax is 340 g and has 8.1 by 6.3 cm dimensions. I would far rather have a little noise if it will give me this kind of size benefit.
