11-24-2011, 03:41 PM   #1
K5 viewfinder / sensor disalignment
Hello everyone,
after a couple of weeks of k5 pleasure I noticed that for all my (handheld only) shots I had to rotate the image about 1-2 degrees in PP for the horizon/other reference to be level. Once I noticed this I started paying particular attention to the alignment, and I can reproduce this error on a tripod.
I know you can do the composition adjustment in the liveview mode, but these settings do not apply outside this menu (or so the camera tells me).
if I reset the composition adjustment, go back to normal mode, align camera on tripod through viewfinder, then switch to liveview the image is rotated like it is on normal shots.
I've reset the camera to be sure it wasn't one of my settings somewhere, but this hasn't helped.
My conclusion would be that the sensor is not quite aligned in the camera. it's a pretty minor thing, but annoying if you frames tightly and can't afford to lose by rotating and cropping.
I see there are some other people which have similar issues, anyone have a better idea to solve this than sending it back?
cheers
11-24-2011, 04:16 PM   #2
It's not the sensor, it's the electronic level. Try upgrading your firmware to the latest version. If that doesn't fix it, send your camera in and they should be able to fix it without replacing any hardware - or you can get it replaced at the store, my first one had this problem also.
adjustment, camera, composition, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5, sensor, settings, viewfinder
K-x Sony Sensor vs K-7 Samsung Sensor karl79 Video Recording and Processing 9 09-23-2010 09:35 AM
K200D viewfinder + Katzeye VS. K20D viewfinder dugrant153 Pentax DSLR Discussion 3 07-24-2009 11:36 AM
K200D Viewfinder vs K20D Viewfinder cputeq Pentax DSLR Discussion 7 06-15-2008 11:57 PM
Sensor cleaning: Pec-Pads or Sensor Swabs gadgetnu Pentax Camera and Field Accessories 29 09-24-2007 10:52 AM
Sensor cleaning > Sensor Swab > void warranty? Twinky Pentax DSLR Discussion 2 07-28-2007 01:10 AM
All times are GMT -7. The time now is 04:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
