02-15-2012, 06:09 PM   #31
krebsy75's Avatar
It is unacceptable that Pentax hasn't resolved this problem via firmware update. Add me to the list of disgruntled owners dealing with this issue. Metz 58 here. Best results obtained with Metz in auto mode or P-TTL with -1 flash compensation.
FIX THIS PENTAX!!!
02-15-2012, 06:28 PM   #32
krebsy75's Avatar
Tried my wife's K-x tonight and no over exposure issues with the Metz 58.
02-15-2012, 11:54 PM   #33
What AE exposure mode/pattern do people have set (matrix, centre, spot?) when they experience over-exposure? Is there a common factor here?
02-16-2012, 04:16 AM   #34
krebsy75's Avatar
I've tried manual, P and green. Metering on matrix.
02-16-2012, 06:52 AM   #35
krebsy75's Avatar
What irks the crap out of me is that P-TTL was acceptable on my K10D, K20D and K-x. Along comes the K-5 and all goes to hell. And they just seem to ignore the problem like it doesn't exist. Serious love/hate relationship with this brand. Okay, rant done.
02-16-2012, 02:54 PM   #36
There is no solution. With my 16-45 at 16mm: need -1.3 EV, at 45mm never need compensation. It is crap.
02-16-2012, 05:33 PM   #37
aleonx3's Avatar
QuoteOriginally posted by ade Quote
Are there a lot of people, who use flash heavily on the K-5, who find that it works most of the time? (I realize any camera will probably blow it some of the time, but I am seeing it most of the time.) Do you think perhaps I should return the camera, and see if another one works better?
I have the k10D, k-7 and k-5,, but I never have any over-expose problems with the hot-shoe flash AF360 or AF540.
02-20-2012, 08:16 AM   #38
In the pics on the first page the K5 exposure looks to be what it would look like outdoors at noon - so from that standpoint it appears to be correctly exposed. The first one is the most pleasing to my eye but I think it is about 1/2 stop underexposed. I have had overexposure problems as well but usually when I am too close and probably should go manual. I have found really like the results when I use "trailing curtain" setting.
02-25-2012, 10:09 AM   #39
Massive over-exposure with my K5 and Sigma 500. Putting the flash on my K10D with the same settings yields correct exposure. For whatever reason I couldn't get my flash out of Pttl mode when it was attached to the K5 (but I COULD on the K10D) so I put my Cactus V5 on the hotshoe and the flash on that to remove Pttl.
- Andrew
04-09-2012, 04:41 AM   #40
K-5 + AF540FGZ overexposure solution found!
tested myself and it works! requires a very simple but careful adjustment.
Follow this thread and it's embedded link for pictures:
Re: P-TTL on K5: Pentax SLR Talk Forum: Digital Photography Review
It appears that during assembly this fine tunning part was either forgotten or improperly done
Kind Regards
David
04-10-2012, 06:00 AM   #41
Have you tried the flash in auto mode since making the adjustment? I'm curious to know if that was also affected by the adjustment.
QuoteOriginally posted by davidsladek Quote
Kind Regards
David
04-10-2012, 08:27 AM   #42
cbope's Avatar
Kind Regards
David
Interesting, but I certainly would not start tweaking unmarked pots on my AF360FGZ, and I'm an electronic engineer. But then again, I do not seem to have the overexposure problem with my K-5 according to test I did a few weeks ago after the latest firmware update.
04-10-2012, 12:11 PM   #43
blockamon: yes, I am using the flash in full auto mode with camera set to P mode
cbope: I was very sceptical to any physical adjustments but since I had a flash unit that I couldn't use and Pentax didn't seem to bother to help resolve the issue, I tried...
af360fgz, camera, dslr, firmware, flash, k-5, k-5 ii, k-5 iis, k5, pentax k-5, people, time
Photo Storage Solutions Anyone? LucyGoosey Digital Processing, Software, and Printing 2 01-03-2011 10:09 AM
What's in lens cleaning solutions? Javaslinger Troubleshooting and Beginner Help 7 09-03-2010 06:59 PM
Trekking solutions needed :) beer_nuts Pentax Camera and Field Accessories 15 05-31-2010 04:39 PM
K20D and Flash Exposure Ed n Georgia Flashes, Lighting, and Studio 2 05-29-2010 01:19 AM
K7 Exposure With Flash Up GoremanX Pentax DSLR Discussion 12 12-30-2009 01:10 PM
All times are GMT -7. The time now is 08:54 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
