Originally posted by aleonx3 Actually, I think they fix the minor inconsistency in k-7. With k-5, you can only move the focus point when the four triangles show up. To do that you have to press and hold the OK button until the four triangles appear (or disappear). With the k-7, it is not consistent.... and you may move the focus point when the four triangles are not there. At least that is what I get from my k-5 and k-7.
If they had the four-triangle icon displayed on the top LCD I might not be so annoyed, but right now I find it a very frustrating and annoying affair, especially when it could be fixed so easily. You'd expect them to have at least carried the K-7 approach if not improved it.
1. Walk into new room, time to change white balance. Need to take a group shot, set up tripod, time to turn on timer.
2. Umm, I wonder whether I was in the AF point select mode or not
3. Press four-way controller, nothing happens
4. Curse. Hold OK button
5. Press four-way controller button, change settings
6. Hold OK button
7. AF point has moved, reset it back to where it was before
8. After 20 seconds of fiddling, get back to shooting
