Originally posted by bobell69 Your problem is that you have your auto horizon turned on. Make sure that both your shake reduction and auto horizon are turned off. I was experiencing the same problems.
I went back to a video taken with a longer lens to test your theory.
During rapid movements I can clearly make out the SR mechanism functioning - in the video it sounds just like it does when you hear it during a photo. It's that dull rubbing noise of the sensor moving about.
The static noise is very different.
The static noise is present in some videos, not others.
The static noise is not the SR at work
All videos were taken with the SR and horizon indication turned on, however not all videos have the static noise.
The once-per-second popping noise seems like a codec issue as it is not present in some other players. The continuous static noise is heard in players where the once-per-second popping noise is not.
