01-02-2012, 03:20 PM   #1
Tom S.'s Avatar
Question for US travelers to the UK.
Will my US version of the K5 battery charger work in the UK if I use a plug converter, or will I need a step down transformer too? The wife and I are going for three weeks in May/June.
01-02-2012, 03:32 PM   #2
Mine has "100-240V 50-60Hz" on the flip side, if yours does too (as I would imagine) UK's 240V 50Hz is covered and so plug adapter should work fine. [edit: continental Europe uses 230V 50 Hz, US 120V 60 Hz]
01-02-2012, 06:56 PM   #3
You'll be fine - if you can find a plug!
Nearly all battery chargers and computer power supplies these days are "universal voltage" and will operate from Japan's 100 v to the USA's 120 V as well as Europe's 220/240V. Just pick up one of those plug converters at the airport and you'll be good to go (if you can find a plug in the U.K., that is!)
I've traveled all over (USA, UK, Europe, South Africa) with my Pentax K10D and K20D and the charger worked just fine everywhere.
Mike
01-02-2012, 08:47 PM   #4
I've taken a variety of Pentax bodies and HP laptops to the UK without problems, using only a plug adapter. As always, check the charger info for your particular gear. And don't forget to let us know where to find your output!
01-03-2012, 05:14 AM   #5
Tom S.'s Avatar
QuoteOriginally posted by jolepp Quote
Thanks! I looked at the charger and you're right it does say 100v - 240v.
Thanks to Mike & GJL too!
01-03-2012, 06:10 AM   #6
Jasvox's Avatar
You'll only need a plug adapter to fit your Yank plug into a Pommie socket.
Jason
01-03-2012, 02:00 PM   #7
Col
QuoteOriginally posted by Tom S. Quote
Avoiding the Olympics eh? Other option is many of the compatible batteries come with a charger which can be used both in car as well as plugged into the wall.
eg
Amazon.com: Wasabi Power Battery Charger for Pentax K-5 DSLR: Camera & Photo
01-03-2012, 09:26 PM   #8
Here is a plug converter...
01-11-2012, 01:21 PM   #9
Tom S.'s Avatar
QuoteOriginally posted by interested_observer Quote
The converter isn't an issue - I have four or five of them. I just wondered about the voltage difference. Turns out I can also use the USB charger I have to charge various batteries like my Nook. Woo hoo!
camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5
K-x AF Question benjikan Pentax DSLR Discussion 16 04-07-2010 10:41 PM
CS 4 Question THAN THE SWORD Digital Processing, Software, and Printing 3 03-08-2010 09:40 PM
Full Time Travelers Bob Harris Welcomes and Introductions 7 02-21-2010 04:54 PM
Question: which one should I let go? senree Pentax SLR Lens Discussion 12 02-16-2010 12:11 PM
An Answer to a question and a question. granitic Pentax DSLR Discussion 5 02-23-2007 09:28 AM
All times are GMT -7. The time now is 02:09 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
