Originally posted by Fletcher Davies First the bad news, the TTL pass through does not support P-TTL so you can't use HSS. However, the generic TTL does work from the triggers hot shoe. OK now the good news, the Strato triggers work flawlessly with no mis fires. The range is over 100 meters and from my tests the channel selection settings all work with no problems. There is an option to fire all channels at once which I think is a good feature. Anyway, the build quality is first rate and all of the accessory leads are also first rate. If you order direct from the Phottix Web Store you will save roughly £35 compared to buying from a UK supplier. These triggers are very, very good, I just wish they could provide P-TTL pass through, but I guess you can't
have everything. I have emailed Phottix with a request for P-TTL, I will just have to keep my fingers crossed.
Hello Phandu, you seem to know about the wireless triggers, maybe you can help me.
I purchased a Phottix Canon TTL wireless Flash to use on my K5, the photo store personnel guaranteed me that it would work, stating the "TTL made in a universal remote". But the sending unit doesn't seem to fit on the K5 and I don't want to force it. Does this trigger work with the K5?
Ramonsito
