Originally posted by alexeyga I'd have to agree with Wheatfield - an operational thing that cancels the AE-L. Something you do while manipulating the camera perhaps?
So pressing AE-L to lock the exposure for twice the metering time & moving the camera to frame the image before pressing the shutter & watching the exposure value change is what should happen - I don't think so; the only manipulation involved in that process is the movement of the camera.
Originally posted by alexeyga That being said, the biggest problem i see - is the way how you use AE-L. It's one these life-proven-truths like "one doesn't take a piss while facing the rain". If you want to take an X amount of frames all with the same exposure - SWITCH TO MANUAL, which also includes either pre-setting the WB manually if you shoot JPG or applying the same WB setting in PP to the whole series of shots if you shoot RAW. Simple really. On the other hand if you want the camera to do the whole work for you, then perhaps K5 is too advanced for your needs. In photographic equipment, the amount of bells&whistles that you get isn't proportional to the amount of $$ that you've paid - actually it's the other way around, the more you pay - the less you get. Take any higher-end camera body, D3, D700, 7D, D300s, K5 and it won't be able to stitch a pano out of JPGs like my 200$ waterproof Panasonic P&S does!!! )))
In terms of creating a panoramic sequence, I know that I can set the mode to Manual & take full control, but it's easier doing it in the same mode (Av) as I normally use and, as it explains in the User Manual, it should be possible.
This something that has been possible with the *istDS & K10 which I've used for many years &
I doubt very much that the K5 is too advanced for my needs! All I expect is the K5 to be able to do what it is designed to do - nothing more, nothing less.
