Originally posted by Anvh Instead of EAL why not use the manual mode with the green button.
You can change the green button function to act like Sv, Tv or Av on demand.
In Manual Mode, pressing the Green Button gives you a correct exposure BUT it chooses a weird shutter/aperture combination which doesn't seem to relate to the Program Line. I have to press the Green Button, then AE-L so as to adjust the shutter/aperture values to suit my set up.
If only the K5s AE-L fuctioned correctly, then we wouldn't be forced to find work arounds!
I've moved across to TAv Mode as this is the only mode where the AE-L button works correctly - fortuneately, the K5s IQ isn't too compromised at high ISO values!
