04-07-2012, 01:06 AM   #1
flash question
I'm using wireless triggers and I can't seem to get the flash to trigger wirelessly in manual mode. It works in automatic and in aperture priority but not in manual. What am I doing wrong?
04-07-2012, 01:09 AM   #2
Your shutter speed needs to be lower than 180
http://jarek.smugmug.com
04-07-2012, 01:21 AM   #3
This is exactly why I love this forum. Thanks alot.
04-07-2012, 03:07 AM   #4
Anvh's Avatar
In manual mode the max is 1/160 because 1/180 is an step in between that it does not normally take. If you really want 1/180 you need to use X mode if your camera has that but the difference is so small...
04-07-2012, 05:30 AM   #5
jatrax's Avatar
As noted that is what the X-Sync setting is for if you have it. I struggled with the same thing for too long. Even blew away a whole shoot at a cemetery because I could not get the remote flash to fire. Only figured out later it was because the shutter speed was too high.
Now if I but the remote trigger on, it gets set to X-sync, then I don't have to worry about it.
04-07-2012, 08:05 AM   #6
Etrsi_645's Avatar
so X-Sync is a manual mode where the camera watches the shutter speed only?
04-07-2012, 09:25 AM   #7
Anvh's Avatar
QuoteOriginally posted by Etrsi_645 Quote
X sync picks the fastest shutter speed for the flash sync, with normal flash that is 1/180 and that's a fixed value then the rest, aperture and ISO are manual.
I believe if you use second curtain then the flash sync drops a bit, not sure though about that one in combination with X mode.
04-07-2012, 10:10 AM   #8
QuoteOriginally posted by Anvh Quote
Very curious why you say that 1/180 is 'in between'. I use 1/2 eV steps and don't have any issues getting to 1/180s and can't get to 1/160s. So 1/160s is something 'in between'
04-07-2012, 10:51 AM   #9
alohadave's Avatar
It's 1/160 because the camera is set to 1/3 stop increments by default. Set it to 1/2 stop and you can get to 1/180.
04-07-2012, 05:29 PM   #10
Anvh's Avatar
Glad you answer each other message for me =]
camera, dslr, flash, k-5, k-5 ii, k-5 iis, k5, pentax k-5
K-x flash question mikknu Troubleshooting and Beginner Help 4 08-16-2011 03:39 AM
Flash question elsdad Pentax Medium Format 3 06-05-2011 03:54 PM
Basic Pentax K-x, hot-shoe, flash, flash bracket, wireless question MrPetkus Flashes, Lighting, and Studio 5 04-27-2010 10:57 PM
question about flash TAP Troubleshooting and Beginner Help 5 04-23-2010 03:04 PM
Flash Question - Turning Off Flash Quickly For a Shot sweetpapa Pentax DSLR Discussion 5 06-16-2008 12:04 AM
All times are GMT -7. The time now is 03:27 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
