04-27-2012, 08:31 PM   #1
formatting problem
Earlier today I formatted a memory card that was already in the camera. I had another one to do too so I removed the first one and inserted the second. (Yes, I turned the camera off before doing that) The camera 'died' or maybe it would be more accurate to say that it was very sick!
The top LCD display flashed P and then changed to the three little lines that indicate Exposure Bracketing. The main monitor was black. The menu button did nothing. Changing aperture, mode dial etc also did nothing. Scary!
I checked the manual and it didn't seem to have anything to say about my problem so in desperation, I removed the battery, hoping that this would 'reset' the camera much like turning off a computer.when it has a glitch of some sort.
It worked .
My questions have to be why did this happen? Is it likely to happen again? What does taking out the battery actually do to the camera controls?
04-27-2012, 08:38 PM   #2
Sounds like some other button was being pressed down, prompting this to happen- perhaps the drive mode one? If you keep on pressing it, your drive mode will change.
battery, camera, dslr, happen, k-5, k-5 ii, k-5 iis, k5, pentax k-5
Memory card recovery after formatting dicks11 Troubleshooting and Beginner Help 18 03-21-2014 05:01 AM
SD card formatting fredok1 Pentax DSLR Discussion 29 04-01-2012 06:02 AM
Formatting/Firmware Update Question Bårsvik Pentax K-5 & K-5 II 5 07-08-2011 11:52 AM
Problem formatting PNY SD HC card in K10D Green_Manelishi Pentax Camera and Field Accessories 10 03-10-2009 06:47 PM
All times are GMT -7. The time now is 10:55 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
