04-30-2012, 10:29 AM   #1
Smaller grip w/o battery as ergonomic add-on
Hello everyone!
I'd like to know if anyone knows about a grip that adds some size to the camera, but not too much. The K-5 fits my hand perfectly, except for the little finger, which is sadly left to hang around. The catch? I have a Kata 144 DL I'd like to continue using, but K-5 + D-BG4 is a combo that wouldn't sit inside the way I like it. So I'm looking for a half-height replacement for the OEM grip. If I don't get an answer I'll DIY something.
04-30-2012, 12:24 PM   #2
lammie200's Avatar
QuoteOriginally posted by Giklab Quote
I seriously doubt that there is anything available that isn't the same dimensions as the OEM grip. You could try an L-bracket, or screw a piece of wood, or metal to the tripod socket. Not very convenient for changing batteries I suppose.
04-30-2012, 12:26 PM   #3
eddie1960's Avatar
nothing available AFAIK. Some people have rigged things up for the KR and Kx though - homemade and generally fugly though
04-30-2012, 01:57 PM   #4
QuoteOriginally posted by eddie1960 Quote
Yeah I've seen that Turkish thing for a K20D-or-something
I want something that stands up to the camera's ergonomics. The batteries aren't that much of a problem. My plan was to buy a OEM-clone (the "type 2"), gut out the top metal plate & connectors and stick something below that would continue the camera lines. + add extra tripod holes to the bottom.
04-30-2012, 02:19 PM   #5
WR
Hello everyone!
You may want to consider WR in your DIY to prevent any moisture from coming in contact with the connectors on the bottom of the K5.
JC
04-30-2012, 03:01 PM   #6
QuoteOriginally posted by jessecad Quote
JC
Already thought of that https://www.pentaxforums.com/forums/pentax-k-5-forum/180849-crazy-idea-re-d-b...r-sealing.html
04-30-2012, 03:56 PM   #7
Ex Finn.'s Avatar
Well, if your pockets are pretty deep, there are rapid prototyping services available. We had something made by Fused Deposition Modeling (FDM) process. It turned out fantastic and only cost couple thousand.
04-30-2012, 09:24 PM   #8
QuoteOriginally posted by Ex Finn. Quote
Heck, maybe someday a do-it-yourselfer could run down to their local electronics store and buy their own 3D printer. There are kits now, but low resolution. There are also durability concerns....
05-01-2012, 05:12 AM   #9
Well, AFAIK the cheapest 3D printer is the Makerbot, which could cost ~1500€. Not budget friendly. And the durability bugs me too. The photo club I'm in is based in a technical school centre, and a primary school also has a sort of hobby club, using the school's tech class equipment.
05-04-2012, 07:52 PM   #10
get some styrofoam and bondo kind of like making a surfboard.
05-05-2012, 07:49 AM   #11
lammie200's Avatar
If you can make a 3-d model you can send it out for 3-d printing. You can search for websites that do it. It is not horrendously expensive, but it depends on what material(s) you want ot use. You can even buy a cheap knock-off of the OEM grip to get the dimensions. You can probably even get that scanned and modify the model to get the shape that you want. Depending on how industrious you want to get, you can probably sell them.
05-05-2012, 11:03 AM   #12
Actually, I thought about buying a knock-off just for the top plate, with connectors and sealing ridges. But that scanning is one heck of an idea.
camera, dslr, grip, k-5, k-5 ii, k-5 iis, k5, pentax k-5
It is 2012 soon...any plain grip that can add a bit of weight to my kx? telly0050 Pentax DSLR Discussion 17 02-08-2013 11:56 AM
For Sale - Sold: K20d with Battery Grip and extra battery + Vivitar 383 Flash mrdfred Sold Items 5 11-05-2011 09:33 PM
For Sale - Sold: Camera, cable release, battery grip, flash, battery pack, 3 lenses and radio t WMBP Sold Items 20 07-15-2011 09:12 AM
For Sale - Sold: K-5, K-7 Battery Grip (Phottix) incl. 2nd Battery (Hähnel) (Worldwide) pentmax Sold Items 5 03-21-2011 03:10 AM
K10D Battery Grip : Excellent add on! yeedub Pentax Camera and Field Accessories 9 03-05-2008 02:23 AM
All times are GMT -7. The time now is 06:44 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
