05-17-2012, 10:21 AM   #1
Best Practice for dust removal setting
I have just purchased a K-5. I m wondering if there is a best practice for the dust removal setting in the camera. Do most users set it to clean the sensor every time the camera is turned on, or is that overkill - or perhaps too much and could damage the sensor in the long run? Should I instead manually run the dust removal function once a week, or month, or only if I notice dust?
Any advice will be helpful.
Thanks
05-17-2012, 10:28 AM   #2
JinDesu's Avatar
I set mine to run when turning on - my camera is almost always pointed downwards when i turn it on, which helps.
Run the manual dust removal function only when you see dust.
05-17-2012, 10:40 AM   #3
StephenHampshire's Avatar
QuoteOriginally posted by markvc Quote
Thanks
I change lenses frequently and dust can be a real problem. I have the dust removal action set to start up, and normally turn the camera off to change lenses. I have to clean the sensor about once a month, although if I do get a dust bunny, running the dust removal action manually two or three times clears most of them. The dust mapping function is really useful.
05-17-2012, 10:46 AM   #4
Otis Memorial Pentaxian
whats your technique for cleaning the sensor
05-17-2012, 10:52 AM   #5
Anvh's Avatar
QuoteOriginally posted by JinDesu Quote
Pentax say to use this feature with the camera up right, there is a special strip under the sensor that collects the dust.
05-17-2012, 10:56 AM   #6
JinDesu's Avatar
QuoteOriginally posted by Anvh Quote
Really? Thanks for letting me know. Everyone else has been telling me to point the thing downwards when doing the shake (I guess for the dust to fall off the sensor).
What happens when the strip becomes full of dust?
05-17-2012, 04:33 PM   #7
Anvh's Avatar
video interview around 11 min
Pentax 645D - First Look Review
strip can be replaced
reason for using upright is also explained.
The shutter is closed when you do this so when the camera points down the dust land on the back side of the shutter and so when you take a photo the dust is back on the sensor.
05-23-2012, 04:49 PM   #8
QuoteOriginally posted by pearsaab Quote
I use a Sensorklear pen - a lightly impregnated pad on a pen-like tool
camera, dslr, dust, dust removal, k-5, k-5 ii, k-5 iis, k5, pentax k-5, practice, removal, sensor
Pentax K-7 Dust Alert and Dust Removal Functions brosen Pentax DSLR Discussion 9 02-09-2016 04:43 AM
Dust Removal ggeorge11 Pentax K-5 & K-5 II 4 05-29-2011 07:02 PM
K-r Dust Removal fototix Pentax K-r 12 03-16-2011 04:34 AM
K-5 Dust Removal and SR leadfoot Pentax K-5 & K-5 II 7 02-26-2011 10:26 AM
K-5 Dust Removal G-Diesel Pentax K-5 & K-5 II 8 01-23-2011 05:34 PM
All times are GMT -7. The time now is 12:42 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
