Originally posted by vonBaloney Yes. It is quite common for it to occur inside lenses. Sealing has nothing to do with it -- there is air in there. So you probably had a cool, dry camera/lens (maybe even air-conditioned) and then you took it out into the heat and humidity -- bang, instant condensation. If you want to avoid this, let the bag heat up in the sun (closed) for a while before opening. I've also heard it suggested to keep the camera in a ziplock bag and then when you bring it out into the heat (still closed) you'll get condensation, but it should be mainly on the inside of the bag and not the inside of the camera/lens itself. If you are moving from air-conditioning to high heat and humidity, that is the worst situation, but any cool/dry to warm/humid change is a possibility. Most of the time there is no lingering effect -- just make sure once it fogs up you leave it in the heat long enough for it to clear up...
Thank you very much for your great explanations! Maybe things are not that bad after all. As I understand through your words: because there is air inside the lens, in consequence there is also water inside the lens. Which means that the higher the environments air-humidity, the more water there is inside the lens over time....
Well, I am a bit more at ease. Again, thank you very much for your time and willingness to enlighten my case!
