05-30-2012, 01:20 PM   #1
Monitor goes blank with cable release installed
I have a question about my K5. I have searched the forum and read the manual but can't find an answer. I have an older Hama electronic release cable. I used it with my Ricoh XRM's for years. Just a standard 3m jack. My questoin is this:
Whenever I plug the cable release in my monitor goes blank. If I take a shot no preview available or anything. If I press the menu button same thing. Nothing. As soon as I remove the plug, the monitor comes back on. Is this normal? I have tried installing the cable with the camera off too and it made no difference.
Thanks in advance for any info.
05-30-2012, 11:04 PM   #2
philippe's Avatar
Is that old Hama-for-Ricoh cable release wired the right way?
When the AF and/or the shutter release connections or mixed up, then things can go weird.
When I made my DIY cable release, I had the wiring mixed up by carelessness, then the screens and actually the whole camera went nuts...
The correct diagram for a DIY cable release can easily be found on the net, search for the Canon cable release with a 2,5 mm jack, it's the same as for Pentax.
05-30-2012, 11:19 PM   #3
QuoteOriginally posted by gaweidert Quote
That's not normal.
If the release cable uses a 3mm plug it will not work as the camera has a 2.5mm jack.
05-31-2012, 03:07 AM   #4
philippe's Avatar
If that cable release is mono phased, what I think it is, no AF function, and thus has only two connections, then it will be shortcutting jour Pentax because this one has two phases, one for the AF and one for releasing the shutter by this it will need three connections.
Have a look at the jack and see if there are three connections divided by two black plastic rings...
05-31-2012, 05:23 AM   #5
Thanks for the replies. It is a 2.5mm jack but only has one plastic ring. I guess it's time to order some new accessories.
cable, cable release, camera, dslr, k-5, k-5 ii, k-5 iis, k5, monitor, pentax k-5, plug, release
Cable release CS-205 for K-5? Don Boyd Pentax K-5 & K-5 II 8 01-11-2016 02:55 PM
DIY DSLR K-X “Cable” Cable Release trailrider Do-It-Yourself 4 07-11-2012 10:18 PM
D.I.Y. cable release for K-X crazysaint222 Pentax Camera and Field Accessories 4 02-12-2011 02:13 PM
k20d blank monitor raindear Pentax DSLR Discussion 9 09-17-2008 05:25 PM
All times are GMT -7. The time now is 06:06 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
