Originally posted by SMC Will also be purchasing a new PC when I return. From a photographers viewpoint suggetions would be appreciated on MAC vs PC and software to be used to process the RAW photos
I'll start with an obvious question first; any budget restrictions? No matter which type of computer that you do go for it would be better to try to get one with 8gb of ram. Also preferably a 64bit o/s. I'd also strongly suggest a ssd drive; preferably the largest that you are able to afford. With ssd one won't have to worry about timely need for defrag; especially with larger camera memory cards. Also generally speaking; if you do NOT get an ssd; do not get a camera memory card of more than one half of your computer's built in hard disk - otherwsie there will most likely be issues.
That should be a good basis for starters
