07-07-2012, 07:27 PM   #1
filters for pentax 18-135 mm compatible with hood
Hello everyone,
Can you please let me know what branded filters can I use with 18-135 mm lens and hood on ?
07-07-2012, 07:33 PM   #2
crewl1's Avatar
Other than cokins that have the square format any normal screw in filter should work.
07-08-2012, 01:46 AM   #3
Docrwm's Avatar
Just make sure its 62mm.
07-08-2012, 02:42 AM   #4
QuoteOriginally posted by Docrwm Quote
Or larger with step down rings.(Cheap method of having Circ. Polarizers for all your lenses, buy an 82 or 87mm)
07-08-2012, 03:19 AM   #5
Zav
Zav's Avatar
QuoteOriginally posted by Eulogy Quote
And what if 82 or 87 is larger than the lens hood? ;-)
07-08-2012, 10:08 AM   #6
QuoteOriginally posted by Zav Quote
Then buy a 82 or 87 threaded hood?(You'll probably still be saving a large chunk of dough, even for two lenses.[Hoods are cheap, glass isn't, sadly])
07-09-2012, 02:00 AM   #7
steve1307's Avatar
But for a DA18-135 you need a petal shaped hood so it doesn't vignette in the corners at wide angle.
The screw in hoods are mostly all circular if I recall correctly. Also the hood will rotate if used with a CPL and a petal or rectangular screw hood wouldn't be too good .
Just get a 62mm filter and use the DA18-135s own hood with the handy little cutout for rotating a CPL. easy.
07-09-2012, 08:43 PM   #8
QuoteOriginally posted by steve1307 Quote
Or yeah. Only use this logic with lenses which *can* be reasonably worked with.
camera, dslr, filters, filters for pentax, hood, k-5, k-5 ii, k-5 iis, k5, mm, pentax k-5
Lens Hood and Filters ruggiex Troubleshooting and Beginner Help 10 05-26-2011 11:25 PM
What hood F35-135 use? liukaitc Troubleshooting and Beginner Help 2 02-12-2011 08:00 PM
All times are GMT -7. The time now is 09:56 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
