Originally posted by Clavius When mounted on a tripod, with liveview on and shakereduction off, my K5 is making very scary noises. It sounds like the sensor is bouncing around: Click/Clack/Click/clack. Also the liveviewscreen seems to switch back and forth between two images.
I've never had this happen before, I've been a happy K5 user for over a year now.
What am I doing wrong?
Well, according to my ample experience (and surprise in the beginning); if you depart from a status in LV and then take the picture (thus departing from an exposed sensor, thus upped mirror and opened shutter), the mirror which was up in LV will go down after the picture is taken. Then the 'preview' of the token shot will be shown, once the preview show is ended (lasting as long as you programmed the camera for) then the mirror will be upped again in order to show the LV.
So, the sequence would be: up for LV, stay up for the shot, down for the preview, up for the LV . But if you take the shot with the release button on the camera, the the mirror will be lowered to perform an AF, and then upped to shoot, thus adding two mirror movements to the sequence, if you use a cable release these last tow mirror flops will not happen and no extra AF will be performed neither. The AF done by pushing the camera's exposure button is not performed the same way as the AF performed during LV with a cable release.
That might be the cause of what you described as "Click/Clack/Click/Clack": the noise made by the mirror.
Note that the shutter is producing a little noise to, just before the shot (opening), after the exposure (closing) and after the preview then opening for the LV...
I sencerely hope that you understood what I was trying to tell
And I do hope that I am NOT getting lost in translation
(or just would like to be...)
